Need Advice - F1 hood springs - Ford Truck Enthusiasts Forums
Old 03-15-2012, 10:19 PM
OldLugNut OldLugNut is offline
OldLugNut is starting off with a positive reputation.
The power brake & hydraulic clutch m/c & battery location keep me from installing stock hood springs on my 49 Ford F!. I have the outer hinges mounted and a fabricated rod up front to hold the hood open, but without the inner hinge/springs the rear of the hood rattles on rough roads. There's about a 1/4" movement at the hinge pivots that lets the rear of the hood move up/down. I'm fine using the rod up front to hold it open, but need some kind of spring(?) mechanism to hold the back of the hood tight when closed. Does anyone have suggestions for a simple fix? I'm going to browse the local pik-n-pull & see if anything there gives me a revelation, but thought I'd check here in case someone here has solved a similar problem.
Old 03-15-2012, 11:26 PM
Moe Craig's Avatar
Moe Craig Moe Craig is offline
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
Pic of your setup would help
Old 03-15-2012, 11:47 PM
I'll snap some pictures tomorrow & try to research how to post them.
Old 03-16-2012, 01:21 PM
Unhappy
Can't figure out how to post or attach pictures -- probably because I'm older than my truck.
Old 03-16-2012, 03:30 PM
OK, I think I found the method to post pictures:
The outside hinges allow me to open/close the hood & it keeps alignment fine when closed, but there's just enough slop in the pivot bolts & rivets that the rear of the hood rattles up/down on rough roads.
Old 03-16-2012, 03:37 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
How about installing some struts commonly found on SUV rear glass and some wagons? You'll have to fabricate some brackets on the hood brace and the cowl. I'm sure that the "new" struts positioned in similar fashion as the original brackets will keep your hood closed tight in the center. Plus, the struts will also help with holding the hood in the up position.
Old 03-16-2012, 04:42 PM
malatious's Avatar
malatious malatious is offline
malatious is starting off with a positive reputation.
I know you don't want to hear it, but maybe you could move a couple of things and get the spring hinges back in. Also, I think I have read on the forum of people reworking the outer hinges to tighten them up, maybe that would do the trick for you. Maybe some extra rubber bumpers in key spots to keep the hood from rattling.
Mal
Old 03-16-2012, 04:45 PM
teched's Avatar
teched teched is offline
teched is starting off with a positive reputation.
I have attempted the strut idea. I got a couple out of a Kia at the junkyard. They held up the rear hatch. Seamed pretty strong, but not strong enough to hold up the 48's heavy hood. Maybe some struts from somthing like an SUV.
malatious's Avatar
Oh, nice looking truck by the way. Four wheel drive too. Very cool.
Mal
Old 03-16-2012, 05:37 PM
I also considered the strut idea but have had bad experience with them. I want to keep the existing rod support up front, so I'm not worried about holding it open. The rod I have is attached to the front of the hood. It's hollow & the bottom slips over a pin when in use & slides down inside a hollow retainer when hood is closed. Extra bumpers raise the hood up too much -- maybe I can come up with some kind of bushings for the existing hinge pivots to snug them up. That might allow me to use some slightly thicker bumpers. I appreciate all your comments & suggestions.
Old 03-16-2012, 05:42 PM
Rj Williamson Rj Williamson is offline
Rj Williamson is starting off with a positive reputation.
hood hinges
my 85 camaro has some heavy struts to hold it up maybe a set of them would work for u
Old 03-17-2012, 05:44 PM
needhelp49 needhelp49 is offline
needhelp49 is gaining momentum as a positive member of FTE.
could you move the hinge to the other side of the slave cyl then move the mount on the hood or put a longer pin and spacer on the hinge
Old 03-17-2012, 09:51 PM
I don't have the original spring assemblies anymore. Even so I would have to modify my battery location as well as modify the driver side, which I don't want to do. Besides, I really want to keep the front rod arrangement I have for holding the hood open. I've had problems in the past with old truck hoods (not Ford) that would bend when the metal got weak using the stock spring assemblies & just prefer a simple rod. I did insert thin bushings on a couple of the outer hinge pivots today & it made a little improvement. There's no metal-to-metal contact between the hood & cowl, it's just the combination of slop on all the outer hinge pivots that cause the hood to rattle on the pivots on rough roads. Tomorrow I'll try putting a strip of weatherstrip on the existing cowl seal & see if that doesn't further snug up the hood, per someone's earlier suggestion. I'm probably making a bigger deal out of this than necessary -- I'll lose some of the ambiance if I get rid of all the rattles Thanks again for the tips.
Old 03-18-2012, 09:43 AM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
Hello and welcome to F T E . I see you are from Caldwell Idaho, not far from me. I'm at Parma , about 15 miles west of you. Good looking truck you have, If you cant get the problem fixed and need some hinges I believe I have an extra set or two. In case you want to relocate them. Looks like you have a 4x4 with G M 6 lug wheels. Did you change chassis or adapt the axles to the 49 frame ? I have a 51 in the start of a 4x4 build with a chassis change.
Old 03-18-2012, 10:59 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
A front-tilt hood would solve that problem.
F1 Hood Hinges...Eliminated? Wayne Waldrep 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 08-15-2013 09:20 PM
50 F1 Hood Latch adjustment tip49 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 06-06-2013 07:53 PM
more hood hinge questions jerryst 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 11-24-2012 01:53 PM
Hood spring hinge question SC'79 1973 - 1979 F-100 & Larger F-Series Trucks 15 12-13-2011 10:42 PM
1957 Ford F110 Hood Hinge Springs ctaylor57 f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 09-30-2011 08:11 AM
Tags
1950, 1951, 1952, 49, aligning, f1, ford, hinge, hinges, hood, install, opens, springs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
