1994 F150 XL Need Info on Airbag light !
Ok ya Guys on here have been very helpful ,, Recently posed on here about Airbag Light flashing a code (32) , knew when I got the truck , previous owner had changed out bumpers. It is apparent he didn't tell me everything!!! try to use the horn and find out it doesn't work , The truck has a E40D tranns. and the OD shift button only works around 40-45 mph . When you turn the Ign. switch on a series of 5 beeps continues 5 times , plus the Airbag light flashing a 3-2 code!! I have driven this Truck for 7 yrs. with the light flashing this code but no sounds from under the dash . Now it is very annoying to listen to this beeping sound when you start , and sometimes it will beep when your driving it . What the heck do you do to stop it??? Been told to change the airbag bulb in the cluster to stop it , Another said you have to remove Airbag on steering wheel , remove steering wheel to get to the problem ! Never done this before so any help here would help!!!!! If anyone knows what I can do to stop this crazy sound ;PLEASE , tell ! Is the horn tied into this problem also? Or is that another issue? I just want to fix it Right!!
I'll take a wild stab at the beeping sound. I have to ask you does your volts guage work? The guage that tells you how well your alternator is working. On my 1994 F-150, I get a beeping sound and my volts guage stops working. There is a certain fuse that blows out in the fuse box under the dash. That fuse on my F-150 has been blowing from time to time with no rhyme or reason. If your volts guage is working, you can probably disregard this post.
The series of 5 sets of 5 beeps is an indication that there is a minimum of two faults, first your original concern that flashes the indicator, second that the indicator circuit is no longer operational. The tones of 5 sets of 5 beeps should of began when the air bag indicator became inoperative. This is the reasoning behind recommendations to replace the bulb you recieved. Even though this will not repair your original concern, repairing the air bag warning lamp circuit will elimate the tones. This is a redundant system to make sure the operator is aware their is a failure in the air bag system. Most probable cause of the warning lamp failure is the bulb itself. To gain access to the bulb, pull headlamp switch out, their is a small notch in the back of the **** depress the spring retainer pulling it toward you, releasing the ****, pulling it of the shaft. Remove the trim panels left and rt of the column, held in with snap retaining clips. Behind these two small trim panels there are two screws. remove these and the rest of the panel is held in by the same snap retainers. Carefully remove the retainers a section at a time pulling out on the face trim panel. Unplug fuel tank selector switch if equipped. Four screws remove the cluster, may be necessary to remove shift indicator or cable if you have an automatic trans. Sometimes you can grasp the bulb thru the front of the cluster and remove and replace the bulb with needle nose pliers. Inspect the bulb, hopefully its nothing more than the bulb otherwise further diagnosis is required.
Again, the beeping is indicating the SRS indicator lamp has malfunctioned, bulb burned out (from driving it 7 years with it on!) Speicher has given you a good procedure for replacing the bulb. Since you have now posted the code, 32, it indicates "Driver Side Air Bag Module High Resistance or Open" and that along with your statement that your horn doesn't work would seem to point to the clockspring (sliding contact) under the steering wheel being bad. The air bag sensors are not on the bumper so the previous owner changing that out is irrelevant to your problem. The sensors are mounted on the inside of the radiator support. Forget the sensors though as they are not your "priority" problem with the SRS. Replace the bulb and the clockspring and your SRS will be operative again and your face will be much happier on occasion that you meet with an opposing object. See diagram and discussion. Posted part number is F4TZ-14A664-B and there are some on EBAY or from one of the SPONSORS here.
Ford clockspring replacement - YouTube
Thank You ,, ncranchero and Speicher for your help ,, Super!!!! It seems I'm being tested here or something ! LOL Went to pick up clock spring and new bulb , also picked up a few things to fix wife's vehicle , Don't get tired of me on here !!! But seems I'm caught in a DOMINO Effect with my truck ,, But any way , parts house gave me wrong part , sooooo,, jumped in truck ( haven't had chance to change clock spring and bulb yet ) and GEE, NOW THE TRUCK WON'T START !!!! So more info from you is going to be a big Help on here! All I can do at this point is run tester (koeo) and see if it will give me a code ,, and try checking fuse's . Truck will turn over with no problem with key , just not hitting !!!!
I'll warn you! If you mention my name more than once your fuel pump will go out! Fuel pumps hate me. Uh-oh, you need to delete one of my mentions above or you're done for.
What are your symptoms? You hear the fuel pump whirring when you turn on the ignition switch? Have you reset the inertia switch?
Thanks ncranchero !!!!!!! What else Can I do at this point ,
Is your truck a single fuel tank? Check for momentary power on both sides of that inertia switch you found.(correct, if the button is down it's not popped. They are bad to toast the terminals though.) I just bought the pump off of eBay, a no-name one even, $40, have bought several of them & had no problems.
