2005 f150 upper control arm question - Ford Truck Enthusiasts Forums
Old 03-15-2012, 08:54 PM
RayKnappCarpentry RayKnappCarpentry is offline
RayKnappCarpentry is starting off with a positive reputation.
I have to replace the upper control arm on my 05 f150 4x4. I've been looking around the site and didn't see anything. Is there directions posted anywhere on the procedure? or can anyone tell me at least if the strut assembly has to be removed? If so do I have to compress the spring first? Any helpful tips?
thanks
Old 03-15-2012, 10:08 PM
DieselBeast01's Avatar
DieselBeast01 DieselBeast01 is offline
DieselBeast01 is gaining momentum as a positive member of FTE.
I don't think the strut assembly has to be removed. Even if it does, you won't have to compress it any. It has one large bolt on bottom, and 3 small nuts on top. I think the tops are 15mm and the bottom is like a 27mm.
If I remember correctly from putting on my leveling kit, all you have to do to get the a arm out is knock the ball joint loose. It will seem like it will never come out when your beating on it but all of a sudden it will pop loose. Then take the upper bolts out of the a arm and viola, you have you a arm out.
Old 03-16-2012, 05:43 AM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
I believe you will also need to disconnect the sway bar and tie rid, so the lower control arm can drop far enough out of the way. I would recommend doing the Lower ball joint while your in there, and an alignment when your all done
Old 03-16-2012, 12:26 PM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
yup ! An look real close at the idlers arms to, they loosen over time an can be real bothersome to keeping the wheels tru.
Old 03-19-2012, 03:45 AM
Quote:
Yeah he is right, I forgot all about the sway bar. There are two nuts on the bottom of the lower a arms that will release it. I think they are 15mm too.
EDIT: If you don't mind me asking, how many miles are on your truck? Just wondering how long it will take mine to wear out.
Old 03-20-2012, 08:03 AM
dgndngrngr84's Avatar
dgndngrngr84 dgndngrngr84 is offline
dgndngrngr84 is starting off with a positive reputation.
just replaced mine and if you take the strut out it makes it way easier to get to the upper control arm bolts
Clint- I have 98k on mine and my upper and lower ball joints are shot
Old 03-20-2012, 08:24 AM
bigunit54's Avatar
bigunit54 bigunit54 is offline
bigunit54 is gaining momentum as a positive member of FTE.bigunit54 is gaining momentum as a positive member of FTE.
I am a little worried about my ball joints lately, but I haven't felt any symptoms. What did you feel/hear to let you know they were shot, just wondering. I have 92,000 so I know the time is coming soon to do upper and lower BJ's probably will have new tie rod ends put on too when I finally get new BJ's but I am trying to squeeze out another year.
Old 03-20-2012, 09:04 AM
Supposedly if you jack the truck up a bit to get the tire off the ground and then throw a jack under the lower control arm to get some pressure off the ball joint, if they are bad you'll be able to see alot of movement in them when you push and pull left and right and up and down on the tire. Also a pry bar under the tire can help move it. It helps if someone can watch the ball joints while you move the tire just to make sure its not the wheel bearing. With mine I noticed that when turning while driving the front end felt loose and the inside of the front tires were feathering. I went for a front end alignment and they said they couldn't do it because of the ball joints worn out.
Upper Control arms...alignment? JoSHN 2004 - 2008 F150 0 05-18-2013 12:19 PM
2000 Ranger upper ball joint replacement? Guest user Brakes, Steering, Suspension, Tires, & Wheels 2 01-09-2012 12:30 AM
upper ball joints Mr.Felix 2004 - 2008 F150 9 09-18-2011 09:18 PM
'99 Lower control arm bushings Moto7387 1997 - 2003 F150 2 11-13-2010 08:28 PM
Instructions on replacing upper and lower control arms esnider225 2004 - 2008 F150 10 12-09-2009 02:54 AM
Tags
04, 2004, 2005, arm, arms, bushing, control, escape, f150, ford, lift, loose, removal, replace, symptoms, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
