Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Southern Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
California, Southern Chapter Join Chapter, Leader: wpnaes
  #1 (permalink)
Old 03-15-2012, 05:55 PM
davewave649's Avatar
davewave649 davewave649 is offline
1963 Ford F-100
davewave649 has a great reputation on FTE.davewave649 has a great reputation on FTE.davewave649 has a great reputation on FTE.davewave649 has a great reputation on FTE.davewave649 has a great reputation on FTE.
dwbetran
How to fix vibration
Ok guys my truck started having a weird vibration about 2 months ago and I'm still trying to figure out what's causing it. At 40 and then again at 60 the whole truck starts vibrating or shaking slightly. But then if I speed up or slow down it goes away.
So far I've checked:
tie rods
U joints
Looked for bubbles on the tires
I'm gonna get the tire balance checked next weekend. And I'm gonna change the fluid in the diff. Any other ideas on how to narrow down what's causing this?
Dave
  #2 (permalink)
Old 03-15-2012, 06:22 PM
turbohunter's Avatar
turbohunter turbohunter is offline
1963 Ford Thunderbird
My Garage
turbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to behold
It's usually tires if you rule out the obvious stuff as you have done.
I just had the exact same thing happen.
No obvious signs.
__________________
'08 Super Duty 6.4, '61 Unibody, '63 T-bird, '66 Mustang
'76 F750 Firetruck, '83 F150, '74 F-1004x4 shrtbx
And not enough time to drive 'em.
Marc
  #3 (permalink)
Old 03-15-2012, 07:27 PM
william_04_x's Avatar
william_04_x william_04_x is offline
Interstate Menace
Garage is empty, add now
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Carrier bearings do wierd things when their rubbers fail.
  #4 (permalink)
Old 03-20-2012, 11:49 PM
Jetcopterpilot's Avatar
Jetcopterpilot Jetcopterpilot is offline
1964 Ford F-250
Jetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputation
Quote:
Yeah I am with you on this William.. My Carrier Bearing rubber failed, and it felt like it was going to shake the truck apart. It also needed a bit of shimming to get the proper shaft alignment too! Double check those U-joints too!
__________________
May God Bless
1964 F250 custom cab
1964 1/2 Mustang W/ high -po 302
2002 Mustang GT convertible
2005 Crown Vic PI
1967 Sanger flat bottom with blown Olds 468
  #5 (permalink)
Old 03-20-2012, 11:52 PM
1964 Ford F-250
Oh one other thing check the bearings for excess play!
__________________
May God Bless
2005 Crown Vic PI
  #6 (permalink)
Old 03-21-2012, 01:01 AM
1963 Ford F-100
dwbetran
Quote:
By carrier bearing im assuming u mean for a 2 piece driveshaft? cuz i only have a single piece.
And what other bearings were u talking about?
__________________
Dave
1963 F100 "Wrongbed" - 302/C4, shaved drip rails, crank switch power windows, aluminum radiator and trans cooler and still a work in progress
http://s1084.photobucket.com/albums/...cpZZ1QQtppZZ32
  #7 (permalink)
Old 03-21-2012, 01:41 AM
1964 Ford F-250
That's right you have that stubby little truck The carrier bearing is on the two piece drive shafts. another thing to check is your transmission Mounts, if the rubber has failed, it will cause the alignment of the drive shaft to be off a bit. If it is a tire issue it is most likely a front tire, as most rears out of balance are rarely ever felt unless they are severely out of balance. just start by eliminating the easy ones first... then go from there... I had a vibration I couldn't pinpoint, and after changing U-joints recently it disappeared Although they didn't seem bad , one of them was starting to fail... I only felt it above 65 mph..
__________________
May God Bless
2005 Crown Vic PI
  #8 (permalink)
Old 03-21-2012, 10:07 AM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
2006 Ford F-250
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Bill Pounds
I agree that it is usually tires.
But if that doesn't fix it, check the driveline again. You cannot really check U-joints without removing the driveline. And sometimes the balance just goes sour for no apparent reason. That is when you take the whole shaft to a driveline shop and have it rebuilt and balanced.
You might be able to tell a problem with tires from a problem with running gear. If you can feel anything in the steering wheel, it is probably something in the front end, including front tires. If you feel it in the seat of your pants and the soles of your feet, it is probably running gear. But admittedly, often you just cannot tell by feel.
__________________
Folks call me Bill. Why, yes, it is a 6 liter. Your jealousy is showing.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back (w/CAT),Edge Insight CS,Blue Spring,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto,'08 Diff Cover,Upfitters Retro-fit,Coolant Filter,Custom Man Steps,Keystone 2011 Cougar 278RKSWE,2012 Fusion SE
  #9 (permalink)
Old 03-26-2012, 01:36 AM
1963 Ford F-100
dwbetran
Ok I got the balance checked yesterday and it seems to have done the trick. Both tires were off by .75 ounces according to the guy. Not sure how much of an effect that could have had. Still gonna lube the u joints and check the fluid in the axle.
Speaking of which does anyone have any tricks for draining a ford 9"? There's no drain plug and no removable cover and I would like to be able to change the fluid without removing the third member
  #10 (permalink)
Old 03-26-2012, 09:31 AM
bpounds's Avatar
2 bit Californian
2006 Ford F-250
Bill Pounds
You need a suction gun. You can get one at any auto parts store. Stick the tube in the fill hole and suck as much fluid out as you can. Then refill.
If you got this service done at most lube shops, that is how they would do it, even if you had a removeable cover.
__________________
  #11 (permalink)
Old 03-26-2012, 12:40 PM
1963 Ford F-100
dwbetran
Ok that works. Now I just gotta hope for enough clearance behind the fill plug with the fuel cell being behind the axle
  #12 (permalink)
Old 03-26-2012, 12:46 PM
bpounds's Avatar
2 bit Californian
2006 Ford F-250
Bill Pounds
Shouldn't be a problem. This will be a flexible hose. I believe you can use the same tool to fill the unit that you used to suck it out. Not sure, because I've always dropped the cover. But I've seen the tool in the store. Cheap plastic thingie.
__________________
  #13 (permalink)
Old 03-26-2012, 12:48 PM
1963 Ford F-100
dwbetran
I think I might actually have one in the garage. I'll check in a bit. I have another project to wrap up before I lube the joints and change the fluid
  #14 (permalink)
Old 04-01-2012, 06:02 PM
1963 Ford F-100
dwbetran
Greased the U-joints and the steering today so we will see if the vibration is totally gone when i drive up to SB in a couple hours. Unfortunately spring break is over and spring quarter is about to begin
__________________
Dave
Tags
1963, 2011, back, driveline, f250, fix, ford, shake, speed, starts, thunderbird, tire, truck, vibrating, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
