reverse wheels - Ford Truck Enthusiasts Forums
reverse wheels
Old 03-15-2012, 05:40 PM
Groucho83 Groucho83 is offline
Groucho83 is starting off with a positive reputation.
reverse wheels
Has anybody put a set of reverse wheels on an 80s style truck?
Just wondering. I am in need for a new set because mine are to rusted to balance and riveted ones (un reversed) were spotted at the last trip to the j yard.
Post'em if you got'em
Old 03-15-2012, 09:57 PM
bob_351 bob_351 is offline
bob_351 is starting off with a positive reputation.
what is a reverse wheel?
Old 03-15-2012, 10:32 PM
WHEELS, "How To Reverse Wheels" - THE H.A.M.B.
basically, cutting the centers out of a steel rim and flipping it around to decrease the offset for a deeper dish.
Old 03-16-2012, 09:09 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
The only riveted stock wheels I have ever seen, where for a much older truck, and the centers wouldn't clear the brake calipers on newer trucks. I would highly suggest a test fit before spending any money or time on modifying the wheels.
Old 03-16-2012, 10:21 AM
f100jim's Avatar
f100jim f100jim is offline
f100jim is gaining momentum as a positive member of FTE.
What do you want to accomplish by reversing the offset? Just appearance?
With reverse offset wheels, you are going to add a lot of extra stress to your wheel bearings, the thing is going to dart left and right every time you hit a little bump or dip in the road, and your tires aren't going to clear the wheel wells.
Old 03-16-2012, 11:40 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Call Stockton Wheel and have them make you a set.
Then you can have a set like this 15x10
Old 03-16-2012, 02:18 PM
Quote:
riveted wheels were on trucks up to the 70s
Old 03-16-2012, 02:20 PM
Well, I need new wheels because mine are to rusted to balance out and it is already messing up my wheel bearings. Also, I really like the way the look on the 70s- 60s trucks though I have never seen any on an 80s style truck.
Old 03-16-2012, 02:21 PM
Those look great on that 4x4, but mine is a 2wd and I think that some 7-8" would look great.
Old 03-16-2012, 05:28 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The term "reverse" is old school. The new term is "offset" and there is a positive offset and a negative offset. What you want is a wheel with a lot of negative offset. Just measure what you want, most people who make wheels will make a set for you or sell wheels with a variety of offsets.
Old 03-16-2012, 09:53 PM
Quote:
Got it. That is what I am going for...reverse wheels.
Old 03-16-2012, 11:10 PM
kedwinh's Avatar
kedwinh kedwinh is offline
kedwinh is gaining momentum as a positive member of FTE.
Where are you located? I have a set of deep reverse 15" 5 on 5.5 wheel setting out in my little shop. Don't think they'll work with disk brakes though.
Old 04-28-2013, 01:31 PM
prndl prndl is offline
prndl is starting off with a positive reputation.
I don't suppose you still have those wheels just a sittin around anymore?
Old 04-28-2013, 02:06 PM
oneowner83 oneowner83 is offline
oneowner83 is gaining momentum as a positive member of FTE.oneowner83 is gaining momentum as a positive member of FTE.
Ive used chrome reverse wheels for FIFTY years. No bearing problems, no steering problems, they work fine. Yes If youre going very deep there would be a tire scraping issue. I have what we called spoke rims on my truck that are usually white but mine are chrome, they also come in different depths, just like reversed Ford rims. Deep chrome rims look awesome!
Old 04-28-2013, 04:31 PM
Franklin2's Avatar
They do mess up the steering geometry of the frontend, but most suspensions will tolerate it. If you draw a line through the upper and lower balljoint, where it lands on the road should be the center of the tire. A wheel with a lot of offset throws this off some, but like I said it seems to still work ok. You will feel road bumps pulling at the steering wheel a little more than normal.
Reverse guidance Fieldtester 2017 Super Duty 3 10-25-2016 06:29 PM
Looking to buy wheel spacers! Spencer Barnes 1999 to 2016 Super Duty 0 04-23-2016 10:35 PM
Show me pic's of Duallies working 88dually 1987 - 1996 F150 & Larger F-Series Trucks 6 11-06-2011 03:34 PM
finished up my spare set of wheels. what do yall think? btravis90 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-02-2011 07:28 PM
Got my wagon wheels today bulletsneverlie 1973 - 1979 F-100 & Larger F-Series Trucks 16 08-31-2009 02:32 PM
Tags
15x10, 80s, f150, ford, offset, put, reverse, rims, series, steel, stress, truck, trucks, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
