Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-15-2012, 03:28 PM
montego69 montego69 is offline
Garage is empty, add now
montego69 is starting off with a positive reputation.
1960 Sheetmetal Assembly Bolts
All,
While I'm still busy sanding and thinking about color and assembly, I figured this is a good time to ask a few questions.
1) Everything was rusty from baking in the Arizona sun for 50 years. I think the assemby bolts had paint on them... Not sure. What do you guys use for assembly bolts? I'm talking about all the fine-thread bolts that hold the inner/outer fenders, splash apron, etc together on the front end.
I was thinking about painting all the panels and then assembling. After doing some research here, it looks like jamming everything first and then assembly seems to be more popular. In this case, i'd be painting over all the bolts. won't the paint crack around the bolts and washers as it is driven in the future?
Thanks,
Nick in WI
  #2 (permalink)
Old 03-15-2012, 03:41 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is gaining momentum as a positive member of FTE.
Nick; I'm in this process also. I agree that the paint might crack around the fasteners if painted over. This is cat that can be skinned many ways, each has its benefits. My paint booth/area is small, it's tight with just the 8' bed in there. So I'm painting everything separate and then assembling, using stainless fasteners.
Post pictures and keep us inform on your progress!
__________________
1959 F250 4x4
Wally
  #3 (permalink)
Old 03-15-2012, 03:45 PM
stainless fasteners
Teddy,
I've thought about the stainless fastener route as well. They would look sharp. That's what I'm doing on the interior panels- those will be all stainless more than likely.
Not sure what I'll do with door hinges yet. I just might assemble those with regular bolts and paint over them...
Thanks for the response,
Nick
Tags
1960, f100, ford, metal, sheet, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
