Need Help Front Shocks on 1994 E-250 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 03-15-2012, 04:11 PM
kevin-11 kevin-11 is offline
kevin-11 is starting off with a positive reputation.
Exclamation Need Help Front Shocks on 1994 E-250
Hey I have a 94 E-250 that I am trying to replace the shocks on. Did the rears and they were tough but got them done. I am having a problem getting the top nut off the front shocks. very tight space and cant fit a socket over it no room to turn and stem of shock is to long for socket. I know there must be an easier way to get this done? Heated the bottom nuts and got them off, just stumped on how to do the tops
Old 03-15-2012, 07:51 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
A 'blue-wrench" is usually the best/easiest solution.
Old 03-15-2012, 08:32 PM
blageurt's Avatar
blageurt blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
cut off the nut / shaft with a saws-all.....
Old 03-16-2012, 12:17 AM
Exclamation
OK thanks for responses. First there is no room for a saws all and also once you have it cut off you still would need a wrench to tighten. Now what is a 'Blue Wrench" ? There is alot of room on my 95 E-150 to get to the shocks. But for some reason (Heavier Suspension ?) There is just so little room to work on the tops. Thanks
Old 03-16-2012, 05:43 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
a "blue tipped wrench" is slang for cutting torch!
Anyone trying to change shocks on our E Vans faces this same thing---nearly impossible tight spaces on the top studs, front or rear regardless the suspension. A Sawzall with 9" metal cutting blade tends to be long enough for the rears--fronts you may need to remove the tire for enough access room.
Depending on the brand or construction of the shocks some cutting will probably be necessary since its difficult and time consuming trying to loosen and unthread the front top nuts. If you remove a front tire remember your jack stands for support and safety!
This is a tough task no matter how you approach it-----we've all been there, done that and probably equally amazed how something so simple turns into such a challenge.
Old 03-16-2012, 08:40 AM
PStruwing's Avatar
PStruwing PStruwing is offline
PStruwing is gaining momentum as a positive member of FTE.
Up here in the rust belt I have always used a saw or Blue "Wench" to the shocks out!
Old 03-17-2012, 08:06 PM
Driton Driton is offline
Driton is starting off with a positive reputation.
I havent checked in since last Saturday,but i ran across this today on my own truck changing the front shocks (1995 e-350 club wagon). I used a medium deep socket on it,but i had to hammer the metal above the shock and then wedged the ratchet in there by way of small sledgehammer lol...Took me 45 minutes to finagle this mess,then the bottom shock bolt snapped (major rust throughout),so now i need a shock bolt. So i could only get one side done today .
Gonna sawzall the other side tomorrow and save myself the hassle.
Thanks for the tips guys
I did manage to install the top bolt though,and it took 5 minutes just to hammer and pry the ratchet out from the shock stud.
Old 07-24-2014, 07:47 PM
Steve in NC Steve in NC is offline
Steve in NC is starting off with a positive reputation.
Glad you all are here. Would like to revive this thread.
I'm changing 4 shocks on my 1999 E250. Monroe Gas Matic.
Thanks for confirming use of a Sawzall to remove the rear top bolts - they are tight and will use the Sawzall.
Here's my question - when removing the old shocks do I remove the OEM rubber grommets ? They seem to be in there pretty good.
In all honesty because they didn't drop out --- on the front I left them in. With the new front shock (top pin) I added the Monroe washer and lower grommet - added the top washer only - not enough room on the threaded pin for the new grommet and OEM grommet. Just have the OEM grommet.
All compressed and tightened well.
I'll redo if advised - or can I leave it ?
The rear I'm doing tomorrow - remove the OEM grommets ?
Thanks a lot.
Steve
Old 07-25-2014, 06:59 AM
JWA's Avatar
JWA JWA is offline
Replace any existing grommet or washer that comes with the new shocks. Good advice is to use liberal dabs of a marine-type grease or something silicone based to lube those grommets/bushings.
I would guess its acceptable to use an old grommet/bushing assuming you don't run out of stud threads before the shock is firmly mounted and secured in place. So far with my Bilstein's using their grommets/bushings, washers and nuts there have been no issues as you describe SteveNC.
Same with the rears---if you can fit the new grommets/bushings & washers use them---if not check the shock nuts after a few hundred miles, making sure they're still tight to the cross member.
Old 07-25-2014, 05:04 PM
Thanks for the advice.
Just did the rear today. Had to cut the top stud on both.
The OEM grommets seemed like 1 pc as top/bottom rotated together. I left them in. They're solid.
Used 1 new bushing under the cross member with washer. Only about 1/8" OEM rubber when compressed so added one there. Only OEM grommet on top of the cross member. Not enough stud to add new grommet.
How To Remove Front Driver Side Shock on E350 in 15 minutes coolfeet 1968-2013 Full Size Vans 26 09-12-2016 05:18 PM
Bilstein Shocks Installation on my F-250 Adirondacker 1999 - 2003 7.3L Power Stroke Diesel 80 04-04-2015 08:37 AM
Front shocks, bottom nut...much trouble jbtecnico1 1997 - 2003 F150 9 11-01-2011 06:39 AM
Replacing Shocks: A Tutorial RangerPilot Ranger & B-Series 12 09-03-2006 05:11 PM
E350 Frt Shock Replacment Tip (Old Style) mpsuda 1968-2013 Full Size Vans 1 02-19-2005 05:37 AM
Tags
1994, 2004, 95, 97, change, e150, f150, ford, front, nut, remove, replace, shocks, size, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
