You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Year: 1956 Make: Ford Model: F-100 Price: $10000 Mileage: 70000 Color: Red/White Private or Dealer Listing: Private Listing Location (State): MI Transmission: Automatic Drivetrain: Rear Wheel Drive Color: Red Engine: 1970 F100 302 2-bbl
DEARBORN MICHIGAN area…about 2-miles from Ford World Headquarters…right near Greenfield Village!
FOR SALE: 1956 F100 Custom Cab…running project
Due to unforeseen circumstances I must part with my F100 project…
Bring a trailer and cash and it’s all yours….
Selling as a package. Asking $10,000 or best offer… I have much more that this in the truck AND NEW parts!
1956 F100 --- Red with White top original 2-tone paint
ALL ORIGINAL truck inside & out except for motor & transmission…
302 – 2-bbl AND C4 transmission pulled from a wrecked 1970 F100
...also included is a 2nd C4 transmission that came with the truck...
Fiberglass front fenders…they where installed when I purchased the truck!
PARTS LIST: NOT installed...most NEW in BOXES!!!
2nd set of original rear fenders with spare tire cut-out on driver side fender ---almost NO rust
1970 F100 9-INCH rear axle housing with all brackets removed & cleaned up
Ford 9-inch Big (Torino) Bearing Rear Disc Brake Conversion kit…. rotors are 5 x 4 ˝ Ford pattern…
Ford Racing Parts # M-4204-F28A, TRAC-LOC Limited Slip, with 1536-steel billet case caps
ALL bearings & gaskets needed to assemble rear pumpkin….
NASCAR Ford 9-inch 3:89 ring and pinion set ---Back-cut gears!…from
a NASCAR team down south....was told it has ONE 400-mile race on
it............ PERFECT CONDITION!
New Dutchman 28-spline Street/Strip axles & retainers with bearings…NEED axle SEALS!
Extra “hooded” Daytona pinion bearing support without races/bearings
1956 Running boards --- need a few repairs
2nd set of “short” cab-length running boards…I was going to use these to
repair the long ones!
Total Cost Involved Mustang II style independent front suspension with
tubular A-arms and air springs with sway bar…rotors are 5" x 4 ˝" Ford
pattern…
No Limit Engineering FAT BAR 4-bar parallel rear suspension with air
ride, includes panhard bar!
Accuair Stage II management system with ride height sensors, key
fobs, air line & cutter, moisture trap,EVERY option available!!!….best of
the best!...this is the MOST complete & wicked system I've EVER seen!
VIAIR 400C Dual Performance Value Pack compressors…same ones
sold by Accuair!...no waiting with TWO compressors...SWEET KIT!
12-gallon 8-port D.O.T.approved air tank for air ride system
Art Morrison Enterprises 2" x 4" square steel tubing for NOTCHES…..
............."bent the hard way”…you can view them here ............ http://artmorrison.com/layout.php?y=frames/&x=framekit Look for a section labeled: Special Bends Also Available!
ALSO AVAILABLE!…
Probe Industries SRS #10666-030 flat top pistons Net Head Volume (cc) -4.0.
...and... Clevite Perfect Circle Ring Set: #315-0049-030 1/16" - 1/16" - 3.0mm (std. oil ring)
Early 60’s SMALL BLOCK FORD Buddy Barr/Holley tri power set up!!!
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's 62 Uni 390 C6 Custom Cab Not Yet Sold
Looking to buy a 48/50 F Anything If ya have one contact me. Don't just Modify it Fordify it
Just way to many mods. If it had the Y block and 3 speed overdrive I would give ya 12k in a heart beat. Think about it bud
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
