6.0 f350 egr delete - Ford Truck Enthusiasts Forums
6.0 f350 egr delete
Old 03-15-2012, 01:12 PM
eddiez21f350 eddiez21f350 is offline
eddiez21f350 is starting off with a positive reputation.
6.0 f350 egr delete
just purchased and installed kit from alligator performance. kit did not come with provision for stock egr sensor plug. resulting in engine light on ?? what do i do?
Old 03-15-2012, 01:22 PM
Sarge261's Avatar
Sarge261 Sarge261 is offline
Sarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant future
Chances are you will need to get a Tuner to turn the CEL off. Also I would find a spot to put the EGR valve, secure it and plug it back in. If unplugged it will not allow the cooling fan to run, or run at the proper speed.
Look at Innovative, Gear Head, or DP tuner for a programmer.
If it were my truck I would have kept the EGR system, just put a bullet proof cooler in it, but the system is already gone.
FWIW I would get some guages to be able to moniter important data like, EGT's, ECT, EOT, Fuel Pressure, FICM Voltage, etc...assuming you dont have any.
Oh Wecome Aboard, and Spend Some Time Down in the 6.0 Fourm.
Sarge
Old 03-15-2012, 01:26 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Your profile says you have an '06, so yes you will get a CEL. Even if you plug the valve back in, in the manifold or not, your truck knows the EGR flow is gone and it will set the CEL.
Your options are a tuner with custom tunes, as was noted above. Or, plug the valve back in to make the truck happy, and cover the CEL with a piece of black tape. I would not recommend option #2, because you won't know when another issue sets the CEL.
Old 03-15-2012, 01:30 PM
will my bully dog tuner be sufficient? thank you for all
Old 03-15-2012, 01:49 PM
bpounds's Avatar
2 bit Californian
Bully is a bad word around the 6.0 world, so I really have no idea if they will do that. It would surprise me if they will, since those tunes must be off-road only. I guess you would have to call them.
Old 03-15-2012, 11:52 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 03-16-2012, 01:45 AM
Snuggyworm's Avatar
Snuggyworm Snuggyworm is offline
Snuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to behold
good call bill on the bully dog tuner. history notes that bully dog tuners are not recommended for our torqshift trannies cos they ride the tranny hard. i have been in my friend's f-250 and we were towing and we heard the tranny blow out.
Old 03-16-2012, 02:09 PM
Kert0307's Avatar
Kert0307 Kert0307 is offline
Kert0307 has a good reputation on FTE.Kert0307 has a good reputation on FTE.Kert0307 has a good reputation on FTE.
My 05 with a bullydog GT doesn't have a check engine light with the valve still plugged in, but it does throw a silent code. I don't notice any performance differences.
FYI, bully dog HAS changed their transmission tuning for the 6.0 since when they first came out. Also, bullydog will not make a tune to turn off the egr. I do know that H&S performance who uses the same hardware as bullydog, but completely different tuning, will turn off the egr.
Old 03-16-2012, 09:22 PM
BLADE35's Avatar
BLADE35 BLADE35 is online now
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Quote:
The Best thing to do here IMO is to install the EGR Valve back into the Intake Manafold and plug it in. It wont hurt anything or affect anything as long as you Didnt put a Plug into the EGR Valve chamber and deleate it that way
AS Dom mentioned Bulley Dog is Bad for the 6.0L
With as MANY Tranneys Iv seen ruined by Bulley Dog Tunners theres no way I would risk using one on my truck
They could change there BD tranney tuning all they want to me the risk is way to HIGH to HOPE they got it right
IMO go with an SCT Tunner with a custom tune Lot of happey folks and is a Proven Product that agrees with the 6.0L
Quote:
Yes sir plugging in the EGR Valve does help keep the PCM Happy
But some of these trucks do go into a Limp Mode with the CEL On
As Long as the truck Doesnt go into Limp Mode you wont notice any Preformance Issues. The Kicker with the EGR Valve unplugged is it affects Fan Operation so if the Fan isnt working right the risk of Overheat is there
Read this thread Cheezit has done some research with it cant remember what MY truck he tested on but Other Folks have noticed similair problems on all years of the 6.0L
Unplugged EGR VALVE & the problems that follow
http://www.ford-trucks.com/forums/97...egr-valve.html
Old 03-17-2012, 01:00 AM
Snuggyworm's Avatar
i agree wif benny on plugging tat egr valve back into the wiring harness. the radiator fan will not work, and on hot days or under heavy loads, she's gonna heat up faster than mama's cornbread on nana's cast-iron skillet.
Any one install a Flo-Pro Polished Aluminum Intake Elbow brkncly 6.4L Power Stroke Diesel 5 08-20-2012 09:16 AM
Need advise on egr delete kit for 6.0 L FORD_F-350. 6.0L Power Stroke Diesel 8 02-29-2012 09:16 AM
Exhaust suggestions, EGR Delete L. Ward Excursion - King of SUVs 5 12-16-2011 07:51 AM
Egr Valve unplug? Troubleshooting. luketrot 6.0L Power Stroke Diesel 2 09-18-2010 06:47 PM
2004 f-250 egr bypass or delete kit TODDXDC 6.0L Power Stroke Diesel 21 12-10-2009 11:09 AM
Tags
03, 350, 60, 60l, bully, delete, diesel, dog, egr, f250, f350, ford, programmer, turn, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
