bio compatable filters
Hey all, I did the hutch and harpoon mod from Strictly Diesel. Have the Baldwin BF 1212 filter on it now. The manufacturer says this filter is rated up to 20% bio-diesel, something about the bio melting the glue if going more than 20%. Strictly doesn't know where I can purchase filters for this set-up that would allow using 100% bio. Has anyone of my brothers run into this problem, and if so, what filter are you using?
Thanks ya'll, Tom
Thanks ya'll, Tom
ROCKS, i'm run'n wvo, so no help here either, but post down in this section...
Bio-diesel, Propane & Alternative Diesel Engine Fuels - Ford Truck Enthusiasts Forums
There's a member here (99-03 threads), "BINUYA", has streetbike for Avatar, anyway, he's run'n 100% bio, so probably away right now, but should have the info as well, if saw your thread..
When I did my in tank mods, I almost went with that same set up, but didn't because of this reason alone since I run B100 most of the year. I'll keep trying.
For what it's worth- I ran rotgut homebrew bio in concentrations 50-70% for a few thousand miles through a BF1212. I cut that filter open after going cold turkey from bio. Did not see any visual indicators of failing glue. That doesn't mean there wasn't failed glue or that the filter would handle 100% bio.
http://www.attwoodmarine.com/UserFil...TER-RGB_fu.jpg
On my fueling cart I have a two stage filtration set up with a 25 micron hydraulic junk prefilter (not biodiesel rated), and a 2 micron B20 rated finish filter. When I changed these out last year after passing over 1000 gallons through them, I saw no degredation of any glues, seals, or otherwise. I also know of several others that use B20 rated filtration without issues. I suspect you could run the Baldwin for a while without any problems, but that's up to you. I am just sharing my own experience and observations. By the way, GPI makes biodiesel rated filtration that might have what you are looking for.
https://www.ford-trucks.com/forums/p...ictureid=17205
The
problem I ran into was finding a filter that
worked on a 1-14 thread mount, (which is
what the Balswin 1212 is). Most common is
a 1-12.
Thanks for the reply guys. I have also found filters with the 1-12 threads. May try and contact Baldwin when I get home this evening.
a 1-12.
NTD
davidwjacob
10-24-2014 08:02 PM
Toreador_Diesel
03-17-2009 02:55 PM
CheaperJeeper
29
07-14-2008 11:24 PM
