So i could use a little help...
So heres another tid-bit.
When i start the truck the batt meter on the dash goes down below the N.
then it sits below the N for maybe 30+ sec. then hops up between the N and O and slowly works its way up to the M. It will sit there even if i give it fuel like something is still pulling off the batts.
Seems like it use to start moving up quicker than that, or as soon as i would start giving it some fuel.
This sound right?
This sound right?
This sound right?
This sound right?
You probably put a hurtin on the starter from all the cranking when it died
Well not that too many folks are chiming in.
I still have this problem. Takes at least 2 cranks to start. (use to start like a bat at he!!)
Got a new alt. and tested batts. again (good).
Today i started it quite a bit of white smoke (50* or so outside) I pulled the air filter off and noticed a fair amount of white smoke come from the valve cover port to the air intake in front of the turbo.
Does this sound like anything???
Sorry to keep bothering you guys about this i just dont want to have to pay someone if I can fix it myself.
Please Help. If i could get some the past questions answered to that would help too.
on
1 Post
#29
#30
