Shifter clearance and engine options
I have a pile of parts waiting on me when I get home from work to do the next part of my build on my 1952 Ford F1. I am planning on later on dropping a 302/3 speed in it, but for right now I am going with the 250/3speed.
I have the 302 on the engine stand and it's going to need a total rework. I have put a tube crossmember in it to mock up for a 302 and to get the transmission in the right spot. The 3 speed behind the 250 will be the same one to go behind the 302 later on. All I will have to do engine wise is make up a set of engine mounts to bolt the 250 to the 302 cross-member.
The main problem I am having right now is the shifter. Modding the factory style bench seat won't be a problem to put a dip in the middle of it, but where it is stilling right now I would have to cut into the main floor behind the trans hole in the cab. I would like to leave the floor pan un-cut if possible. I have seen some shifters like these but have even more dip in them.
They were used in early 30's cars when using 4 speeds in them.
What are all of you manual users using to shift you engine with?
This is what I have in the shop right now to work with. Hope I can just change the shifter arm out.
There are two ways of moving the shifter location on the three speed
Get a top mounted shift from a mid to late 70's Jeep T150 transmission - The shift then will come out where anormal center shift comes thru the floor.
They make a floor shift that mounts to the two rear bolts on the transmission where it mates up to the tail shaft - The shift handle will come up somewhere near the rear trans mount
bigfoot7180
03-15-2024 09:58 PM
Sixoh
20
01-24-2016 05:52 PM
Warhorse86
01-31-2004 09:24 AM
JUSTINWEBER
02-06-2000 08:44 AM
