auto rear window going up crooked then stuck - Ford Truck Enthusiasts Forums
Old 03-14-2012, 12:13 PM
will2045 will2045 is offline
will2045 is starting off with a positive reputation.
so Its going up only on the passenger side and then gets jammed i cant see down into the tailgate. does anyone have a diagram or the rails? is this a common problem?
Old 03-14-2012, 03:44 PM
Raleigh1's Avatar
Raleigh1 Raleigh1 is offline
Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.
Sounds like the regulator to me, my guess is one of the blots on the driver side arm has fallen off.
Old 03-14-2012, 06:24 PM
AzPete's Avatar
AzPete AzPete is offline
AzPete has a good reputation on FTE.AzPete has a good reputation on FTE.
Possible one of the square plastic slide pieces has broken and allowed the arm to slip out of the track.
Lower the window by holding it straight so it will go down. Open the gate. Trip the latch on the drivers side of the gate. Operate the window in the up position about 1/3 way, holding window.
With the interior panel removed, you should be able to see the slides and fix the issue.
Old 03-14-2012, 08:13 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Mine was similar, the little square plastic slider wasn't broken, it just slipped out of the track. It is easy to look at and feel around with your hand to see what the dealio is, in this same access panel you can look inside at the rails that the window slides on in the side of the tailgate but it is kind of difficult. Get some appropriate lube (whatever these more experienced folks recommend) dip your finger in and run it along the track. I too need to get some of this lube and do mine up nice and fancy.
1999 power windows RSA7.3 Ranger & B-Series 5 01-08-2017 12:16 PM
Wierd vibration from underneath!!! ROBBINthaHOOD Excursion - King of SUVs 3 04-08-2013 08:55 AM
Up pipes on a early 99 ltl_jrw 1999 - 2003 7.3L Power Stroke Diesel 3 05-24-2011 05:38 AM
Petit Jean Swap Meet 2009 tojoski Arkansas Chapter 11 07-02-2009 09:35 AM
Bumper Build brazzealI6f150 Offroad & 4x4 53 03-07-2008 08:55 AM
Tags
78, 86, back, bronco, car, conversion, crooked, electric, ford, half, mustang, rear, slider, sticks, stuck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
