Airbag light flashing - Ford Truck Enthusiasts Forums
Old 03-14-2012, 09:03 AM
ZachF ZachF is offline
ZachF is starting off with a positive reputation.
Angry Airbag light flashing
I just did the odometer fix and put a new led in the headlight switch in my 2001 F150 and now my air bag light is flashing, it flashes 2 times and then 7 times but when I turn the pass airbag off the light goes off. Any ideas?
Old 03-14-2012, 09:17 AM
00GT's Avatar
00GT 00GT is offline
00GT is starting off with a positive reputation.
The air bag light work in the dash? A burned out bulb will throw a code
Old 03-14-2012, 09:37 AM
When the key in the airbag switch is set to on the off light in the airbag switch is off, (duh) and when the switch is set to off the light is on but when I turn the ignition to run the light doesn't turn on for two seconds like it used to. Before I took the dash apart the light used to turn on for around two seconds when I turned the ignition to run and now it doesn't.
Old 03-14-2012, 10:35 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
SEARCH keyword "+LFC +27" for several dozen previous posts/threads.
Old 03-15-2012, 09:16 AM
Quote:
Thanks! It was the bulb.
05 airbag light darylcrutch 2004 - 2008 F150 6 03-04-2009 09:07 PM
Airbag light error code 32, Help... akidagin 1987 - 1996 F150 & Larger F-Series Trucks 6 12-10-2007 01:00 PM
Airbag codes STXFitz 2004 - 2008 F150 8 05-08-2007 09:07 AM
Airbag light flashing fordtrucksforever 1978 - 1996 Big Bronco 30 03-14-2006 07:26 PM
flashing airbag light. marragtop 1987 - 1996 F150 & Larger F-Series Trucks 9 10-22-2002 09:40 PM
Tags
150, 2001, 27, 99, air, airbag, bag, blinking, f150, flashes, flashing, ford, fte, lfc, light, lights, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
