toasted my trans in the excursion it puked out the front seal while towng a large dump trailer , anyway people of CT wheres the best transmission shop in CT?
The factory gray pump seal is known for leaking when over heated. Might just need a pump seal. There is an aftermarket viton seal that will prevent this from happening.
i know its toast slipping and shuddering when you get on it its ok if you drive real easy but as soon as you get on it its a no go so thanks ill check em out
