Can't change clock
Old 03-14-2012, 06:52 AM
11racered's Avatar
11racered
11racered is offline
Can't change clock
When I hit the clock button to change the time on my 2011 F150 the numbers disapear instead of flashing to set the time. Anyone have this problem or any ideas?
Old 03-14-2012, 06:59 AM
shorebird's Avatar
shorebird
shorebird is offline
Your owners manual says to press and hold the button until the display flashes.
Then use the seek buttons to change the digit.
If you have the navigation system there are different instruction in the manual supplement.
Owners Manual online at:
https://www.fleet.ford.com/maintenan...ls/default.asp
Old 03-14-2012, 09:06 AM
loydmeeks's Avatar
loydmeeks
loydmeeks is offline
When the numbers disapear use the station number buttons to put in time
Old 03-14-2012, 01:50 PM
Skoiv's Avatar
Skoiv
Skoiv is offline
That is too funny! I found the F150 clock is the easiest to set out of any Ford I have ever owned. Push clock button and enter numbers!
The following users liked this post:
Old 03-14-2012, 02:16 PM
tuckr2's Avatar
tuckr2
tuckr2 is offline
Clock
Just make sure you put it in park before trying to revise the time. I tried while driving. Didn't work until I put the truck in park.
Old 03-14-2012, 08:33 PM
juneau76's Avatar
juneau76
juneau76 is offline
My 2010 let's me change it on the fly. I don't recommend it but, it let me do it.
Old 03-14-2012, 10:17 PM
flixden's Avatar
flixden
flixden is offline
I changed mine while driving as well. Not fast though, yeah, still probably the wrong thing to do ....
Old 03-15-2012, 11:34 AM
11racered's Avatar
11racered
Thank you, that worked!
When I first set the clock it was the easiest clock I had ever set but for some reason it didn't work as the manual said this last time. The numbers did not flash when I held the clock button, they disapeared and you couldn't use the station up/down buttons. Figured it was something else simple.
Old 01-03-2017, 05:17 PM
Greg Smith's Avatar
Greg Smith
Greg Smith is offline
This worked for me!
I had the engine running, pushed the clock button and then let go of it. Then, I pressed 610 using the preset station selection buttons, and there it was 6:10! Thank you!
Old 04-13-2021, 12:03 PM
DanW911's Avatar
DanW911
DanW911 is offline
Okay figured it out!!!!
1st Turn key to on position.
2nd select AM/FM. ⬅️ This the only thing that different from other attempts I was always on aux. Select am/fm and set your clocks
3rd Press & hold clock button and like magic Set Time appears use the 1 though 0 numbers and set time.
Old 04-14-2021, 01:05 PM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
Exclamation
DanW911 ...
*heads-up* The thread (and posts) are 4+years old.
Also ...
Put your complete vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature. *Eliminated the need to play 20 questions when posting.
» Edit Signature « *And don't forget to [ save ] it.
G3angler
2009 - 2014 F150
11-12-2016 03:25 PM
panelguy
1997 - 2003 F150
03-15-2008 06:43 PM
dbanghart
1983 - 2012 Ranger & B-Series
06-17-2005 08:42 AM
GotLift
06-15-2004 10:01 AM
hermunn123
11-27-2003 11:24 PM
Quick Reply: Can't change clock
