Tow Haul Mode and Tire Pressure
I have a 2015 F250. I was using Tow Haul mode on a down hill while pulling a 5th wheel. My tire pressure sensor came on. After I got to the bottom of the hill and the transmission wasn't slowing me down any more the tire pressure light turned off. Was there a heat build up that effected one of my tire causing a change in pressure in a tire??
Have you checked your tire pressures to see if any of them is on the low side?
Adjusting TPMS.
I see lots of references to a special gizmo required to set the TPMS system with new/different tire pressures. I changed my tires from the recommended (door panel) 65/80 to 65 all the way around. For comfort, not loaded, not towing. My manual has a procedure to reset the TPMS without any added tools or electronics. 2013 F250 18” Michelin AT/2’s. Don’t all the manuals have that?
birddog0903 - I see lots of references to a special gizmo required to set the TPMS system with new/different tire pressures.
Also ...
HINT/TIP: Put your complete vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature. *Eliminates having to play 20 questions when posting.
» Edit Signature « *And don't forget to [ save ] it.
Downriver Thunder
1999 to 2016 Super Duty
24
04-24-2009 04:48 PM
