Intermittent starting problem. - Ford Truck Enthusiasts Forums
Old 03-14-2012, 12:37 AM
SLUF681's Avatar
SLUF681 SLUF681 is offline
SLUF681 is gaining momentum as a positive member of FTE.SLUF681 is gaining momentum as a positive member of FTE.
Question Intermittent starting problem.
My cousin called me today with a problem. I'll give as such vehicle info as possible.
2001 F250, 7.3L, Auto, 2WD, Ext. cab, Lariat, approx. 115k. To my knowledge (and his) there is no tuner/chip on the truck, although I have seen a very small puff of black smoke when it downshifts.
He went out to start it to go to work and it wouldn't start. The starter turns he engine over fine, the tach is moving, but he said he couldn't see white smoke. While cracking, it sounds as if a relay is clicking furiously under the dash. After trying to start it several times, the clicking stopped and the truck started fine. It may not do it for several days, but seems to happen every couple of days. Any ideas?
Old 03-14-2012, 02:00 PM
01PS 01PS is offline
01PS is starting off with a positive reputation.
Sounds like what mine sounded like when my batteries went south. What was the tach reading when this happens? Have him clean his batt terminals and check connections.
Old 03-14-2012, 02:34 PM
SLUF681's Avatar
He said the tach was moving. To what rpm I don't know. He said it was cranking strongly, though he did say his batteries were super corroded. I tried to get him to take 5 minutes to clean them and put some no-a-lox (sp?) on them.
Old 03-14-2012, 02:40 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Sounds to me like it starts after the GPR releases. That is probably when the required 10.5 volts to start is available.
It is most likely dropping below that voltage while GPR is operated.
Old 03-14-2012, 02:48 PM
SLUF681's Avatar
Ooh, good point. I hadn't thought about that. That is a VERY good possibility.
Old 03-14-2012, 03:05 PM
PaysonPSD's Avatar
Quote:
I was on the phone with a member who had a no start problem. Under 10 volts while cranking.
Had him lift one of the control leads off the GPR so it wouldn't operate. Truck started right up.
Old 03-14-2012, 03:38 PM
SLUF681's Avatar
Battery terminals are clean now. I guess we'll see how it goes.
Old 03-14-2012, 03:48 PM
PaysonPSD's Avatar
Have him check for 10.5 volts when he first starts cranking.
Starting problem intermitent pkorrupted Ranger & B-Series 1 05-01-2013 11:09 PM
Hello corvetzo 6.0L Power Stroke Diesel 11 08-05-2011 10:45 PM
06 5.4 problem mstiles19 1999 to 2016 Super Duty 14 12-04-2010 10:46 PM
77 F250 4x4 thoughts on a couple problems pls Graeme 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-31-2009 02:03 AM
Start problems shorebird 2004 - 2008 F150 7 06-07-2009 05:07 PM
Tags
03, 150, 1996, 2003, 400m, 54l, diesel, escape, f150, f350, ford, intermitent, intermittent, intermittently, problems, starting, starts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
