Transmission Line to Radiator Fittings
I am planning to replace the radiator soon on my 1985 F150 with an AOD transmission. The two brass fittings that screw into the radiator transmission cooler for the transmission lines to screw into are in pretty bad shape, and I would like to replace these as well.
Can someone tell me where I can find these, or what these are called and what size? Thanks!
I bought a new radiator for my f100. Have swapped out the original 300 to a 460 so when I replaced the radiator I put one in speced for the 460 which had different fittings.
New radiator had plugs threaded in there so I was able to just take one of those to the hardware store and get the right ones. They are just NPT to flare fittings that you can find at any hardware store. And as I found out....different radiators will have different sizes.
Both were I believe 3/8 flare but the NPT going into the radiator was different. 3/8 on one and the other was 1/2 I think. But again common fittings you can get at most any hardware store...got mine at ACE
Radiator Fittings
The only place I could find cooler fittings for the Ford radiator was here.
Teckpak / Fitzall transmission parts and tools
Hope this helps....
Hope this helps....
MAULMAUL
01-12-2013 05:40 PM
bulabula
02-20-2002 08:18 AM
