2.9L Running rough, bad mileage, I'm stumped!
Hey guys,
I'm having a problem with my 1986 Ford Ranger 2.9L Manual trans, 207,000 Miles. i would really appreciate it if you guys can help me.
Heres the Deal...
When I start the truck up in the morning it idles high and when i go to drive it, it sputters and pops a little. When its completely warmed up it runs rich at times and has a very rough idle and the Rpms fluctuate between 600-1000 Rpms. I use to get 20 MPG now im lucky if I get 15... It runs great on the highway but at low rpms it runs like crap.
Heres all the things I have done:
Prior to all these problems I bought 6 new injectors and replaced the upper plenum gaskets and cleaned the hell out of everything. Ran like a brand new truck. Then less than 1000 Miles later....
New Parts:
Egr Valve, Fuel canister filter, engine coolant temp sensor, Pcv Valve, Air charge temp sensor, Map sensor, New Vacuum lines, New plugs, Wires, Distrubter cap, Rotor, Coil. O2 Sensor.
Things I have tried
Cleaning a spare AIC valve from a junkyard and installing (Not difference)
Swapping junkyard EGR control solenoid + Pressure feedback sensor
Tested the TPS and tested fine.
Tried 2 different computers.
40 psi at the rail with key on and 32 psi with engine running.
I took it by a mechanic today and he said to check and see if the timing chain could of stretched and to do a compression check, Ill do that tomorrow.
I hope I have provided enough information, if you have any questions please ask.
Thanks for all your help!
<!-- / message -->
Heres the Deal...
New Parts:
Things I have tried
<!-- / message -->
I'd try doing a "wiggle test". Basically grab bits of the harness and connectors while its running, and wiggle them and see if engine operation changes.
The next thing I'd try, is disconnecting the SPOUT (spark out, or spark control) connector. If you look just under the IAC valve, you should see a connect coming out of the harness with a plug in it. That plug is the SPOUT connector.
Idle problems in 86 tanger
At 3000 RPM 75 mph it runs great without missing a beat but in the city if I'm sitting idol at 800 RPM the idle will jump down and eventually die Also at climbing a hill it will start to die and I must shift down and gas it to get it up and going again
I have changed the big silver part on top that has to do with idle as well as a plug in part and getting another idle valve part to change hope that does. It but have my doubts Does anybody have a solution to his problem?
Thanks
Martin
Mecone@aol.com
Thanks
Martin
Mecone@aol.com
Pull the vacuum line off the fuel pressure regulator and see if there's fuel in the line, I would bet it's leaking a significant amount of fuel into the vacuum line but still working. My 89 had a horribly rich idol and ran lousy at low RPM but would clear up once the RPMs got higher, the fuel pressure regulator was letting a significant amount of fuel leak into the vacuum line and flooding the engine at low RPM.
tbolt64
45
04-15-2013 11:39 AM
CaptainDon007
04-27-2008 09:02 AM
Full Lock
10-29-2006 09:34 AM
KTMNealio
04-27-2000 03:02 PM
