Back up light switch location - Ford Truck Enthusiasts Forums
Old 03-13-2012, 08:07 AM
70-360fe 70-360fe is offline
70-360fe is starting off with a positive reputation.
Is the back up light switch located inside the engine compartment on the steering column, looks like mine is missing. Is this what I need to get working? Thanks.
http://shop.advanceautoparts.com/web...RPSESWAMS_____
!970 f-100 360 c-6 automatic.
Old 03-13-2012, 09:22 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
If it's an automatic, then it's on the column under the dash, just inside the firewall. If it's a manual, then it's on the transmission. On the 4speed it'll be on the upper housing, left front area. You will need to be either double jointed or pull off the tunnel cover to get to it.
Old 03-13-2012, 09:30 AM
Quote:
It's a c-6 automatic. Just looked on ytube not sure but is it the netural safety switch that turns on back lights or a different switch all together. I know my neutral safety switch is missing, Thanks.
Old 03-13-2012, 09:15 PM
72BigBlue 72BigBlue is offline
72BigBlue is starting off with a positive reputation.
The neutral safety and reverse lights are both controlled by 1 switch, on the column. the connector is a flat 4 prong (on my '72). The bracket also has elongated mounting holes for adjustment, and short mounting screws. The one in your link is for a manual trans.
This is it: NPD Wow, expensive!
Restoring American History | Mustang Parts | Camaro Parts | Chevelle Parts | Ford Truck Parts | T-Bird Parts | Firebird Parts
LMC, part #42
LMC Truck Parts - Page 129
Old 03-13-2012, 09:20 PM
LMC, part #42
Great now I know exactly what it is, thanks.
Man your right about that price have to check junkyard next time I go. LMC isn't to bad so may have to go that route if I can't find one, thanks again!
2014 F350 upfitter switch wire location. tjc transport 1999 to 2016 Super Duty 7 12-07-2014 11:12 AM
1967 f600 back up light switch huck-fin Large Truck 9 07-26-2013 01:03 AM
Neutral Positon switch location chewyacura 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-01-2013 09:03 AM
Back up light switch on a 79 4 speed? Ford59galaxie 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-20-2012 02:05 AM
Backup light switch location FordTruckGuySTX 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-02-2006 07:33 PM
Tags
04, 1968, 2003, back, backup, f150, ford, lamp, light, location, manual, ranger, switch, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
