A lot of play in steering [2006 F250] - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-13-2012, 06:12 AM
WoundedVet's Avatar
WoundedVet WoundedVet is offline
WoundedVet is starting off with a positive reputation.
Does anyone have any tips for removing the large amount of play I am finding in my '06 250? I just purchased the truck late last year and it seems to be a common issue?
Old 03-13-2012, 09:55 AM
Native Tex Native Tex is offline
Native Tex is starting off with a positive reputation.
Not sure what you can do short of checking the front end to make sure none of the ball joints, or control arms are worn out. The rack and pinion is not adjustable like the old vehicles with the steering box. You could adjust them with the bolt and lock nut on top, but thus is not the case with the rack and pinion. Take it to a good front end shop and let them check it out to be safe.
Old 03-13-2012, 09:59 AM
WoundedVet's Avatar
I just replaced the ball joints. Alas, no luck. Oh well.
Old 03-13-2012, 11:13 AM
cbzdel cbzdel is offline
cbzdel is starting off with a positive reputation.
Do you have huge offroad tires? If so I did the same issues until I installed a dual steering stabilizer... Some people say they mask problems, I dont get it, I have stuck them on brand new lifted vehicles and they make a world of a difference..
Play in steering HJM/F250 1987 - 1996 F150 & Larger F-Series Trucks 9 01-09-2016 08:05 AM
ignition parkers5150 1968-2013 Full Size Vans 10 02-24-2014 09:49 PM
Excessive play in steering wheel. BigBlue92 1987 - 1996 F150 & Larger F-Series Trucks 2 09-06-2011 11:34 PM
How to??? Automatic shifter question F250GH 1961 - 1966 F-100 & Larger F-Series Trucks 10 02-15-2011 07:46 PM
nitrous oxide on my f250? gixxer1 1999 to 2016 Super Duty 2 03-13-2006 12:01 PM
Tags
06, 2005, 2006, 250, adjust, f250, ford, lifted, loose, lot, pinion, play, rack, slop, steering, steerying
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
