Fuel reset
Fuel reset
1988 F-250 Automatic 2 wdr Supercab.
Does this truck have a fuel reset button somewhere?
Ive got fuel coming up to the engine but it wont run.
When I dump gas right in the throttle body (take off the hose and squirt it in)it runs great until it runs out of gas.
It has me and 3 other Ford guys stumped?
Any ideas?
Any ideas?
How can I tell if the injectors are firing?
No button on passengers side where I have seen them before.
The engine runs great with gas squirted in the throttle body so the injectors must be firing?
Have a read here, might find some good info.
As for testing the injectors I'm not positively sure but someone might chime in or you might find it in the link, there's a troubleshooting spot there
http://oldfuelinjection.com/
on
That's right this means your injectors aren't firing. The problem is most likely related to one of the distributor components or the wiring between it and the computer, so pull the codes to see what is stored first and if you get anything related to PIP, TFI, or Spout this diagnosis is confirmed.
Yes on the safety wall by the parking brake.
If you are hearing both the pump in the selected tank and the one on the frame rail running then more than likely you have a computer problem.
