You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
The 71 F600 I picked up has some issues, and was wondering what options are for swapping it. It of course has the brake drum on the back, so does this make use of 4wd transmissions for anything newer? Have an idea, if I get ambitious, could swap it to a diesel I have, and have a 4wd as well as a 2wd trans available, but both of course do not have the parking brake drum on the back. Just wondering if they could potentially be refit for the parking brake. Both are T-19 transmissions.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
what tranny came with your F600 ?
is it a 4spd or 5spd ?
the 5spd would be a clark , the 4spd would be NP435 as far as i know !
every 5spd we had in these trucks were the clark , and of the few that were 4spd they were the NP435 !
This one is 4 speed, kept trying to go for 5th which wasn't there... as in, it can't go into it. It has the 2 speed rear axle as well. Good to know it is an NP435, they will trade with the T-19 if need be, I also have a spare NP 435 now, just in an F250.
__________________
2 speed works fine, I have run them before. The truck drives nice, other than the trans has issues with 1st and 2nd.
__________________
