235/75/15 now how do I calclate speedometer
you can do a couple of things. I did the same with my 94, the speedo remains pretty close, the odometer is off by 4 miles per 100. you can either get out on a highway and run at 60 mph over a measured distance like 10 of the mile markers. Start the clock when you go by the 1st and then not time when you cross the last. Then do a search for a milage conversion site. I used to have one but cant find now. it will ask for your time for the distance and tell ya the speed. Its important to maintain the chosen speed. also you will have noted the odometer and then you can calculate the difference. found a link for ya:
http://www.machinehead-software.co.u...time_calc.html
An easier way is with one of the new navigators they have a speed readout that is accurate as sit is GPS based.
Ford also sells a converter gear for the trans. Tell them the tire sizes and the trans rear end info and they will sell it to ya less than $10. I got one but it made things worse so I left my original in.
Thanks for all the feedback....I used the GPS idea and that was reporting 65 from the when the speedo said 60...........I also found this calculator and that came out to be just about the same.......the speedo says 60 and you are actually going 66
Tire size calculator
If you google "tire size calculator" you will find lots of little apps to calculate the difference in tire size and effect on your speedo reading, including:
Tire Size Calculator - Compare Tire Sizes
Later: Oops - sorry. Missed the OP's response where he had figured/found this out already!
no pics. I bought them off of CL. the tires are almost new..probably about 5k on them....goodyear wrangler rts?.......they came off an explorer...........the aluminum rims are pretty beat up.......I paid $200........truck riudes much better.....the old tires made it feel like driving a go-kart compared to these.
caliabrate speedo
check your speed between mile markers.then get different teeth speedo gears like the one that goes in to your tranny.then pick the one that is as close as possible.i used to run 30-950-15s.untill i wore them out.but when i figured out which gear worked.my speedo was accurate within one tenth .
thanks for the 96 2.3 timing picture.
yes im working on a 72 sedan deville that i got for 500.00.the guy i bought it from put a new timing chain.it runs good .now im detailing it .
thank everybody
lrd56
thank everybody
lrd56
"Question, if my ranger has smaller than stock tires, will it make a difference in the speedometer? If so, what kind and I plan to bring it back to stock.... "
Yes. Use the previously posted GearCalc program to determine the difference. To bring your truck back to stock, you need to get the proper sized tires. Using undersized tires may result in exceeding the load capacity of your present tires.
I ran undersized tires once (to save money on the tires). I noticed that I had a slight increase in power on the hills and an equally slight decrease in gas mileage. The speed-o-meter registered about 6 or 8 MPH faster than I was actually going at 60. After i wore those tires out, I returned to using stock tires. (98 Ranger 3.0 5 speed)
