Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 03-12-2012, 03:07 PM
Doc's Avatar
Doc Doc is online now
1949 Ford F-Series Pickup
My Garage
Doc has a great reputation on FTE.Doc has a great reputation on FTE.Doc has a great reputation on FTE.Doc has a great reputation on FTE.
Surprise "fix" to the EGR tube/manifold leak
So I've driven my 97 F-150 (4.6 L) around for several months now listening to that wretched left side exhaust leak caused by the nut on the EGR tube rotting off the nipple on the manifold. I tried plugging it, taping it with that exhaust "bandage" tape, etc. Nothing obviously ever lasted. And I sure didn't want to try replacing the manifold and then dealing with the potential broken studs, etc. Then I finally got around to getting the gas tank straps replaced with that recall. So I took it to the dealership this past Friday. I mentioned the EGR tube leak kind of in passing. The service manager said they could fix it for about 80 bucks. He said they had successfully removed quite a few of those nipples without replacing the manifold. I kind of thought to myself "yeah right" (considering I live in the rust belt with all the road salt, etc.) and told them to go for it. Not surprisingly, they called me back later in the day and said they couldn't get it out, and he quoted me an $800 price to replace the manifold, etc. I just told him to plug it instead. When I picked up the truck, I learned the mechanic decided to WELD it instead of plugging it. I was pretty surprised that he tackled it, and he actually did a pretty decent job in sealing it except for one small pin hole on the back side between the welds. I mixed up some JB Weld and filled the pinhole. The welds may fail or the JB Weld blows out tomorrow, but, in the meantime, I don't have to listen to that wretched exhaust leak constantly. At least I'll have a few days peace if not longer.
__________________
Shane
1949 F1, Stock / 1950 F-5
1950 F1, 302, AOD (still in a lot of pieces)
1997 F150 XLT, 4.6L
2008 F250 XLT, 6.4L Powerstroke
2011 Expedition EL
  #2 (permalink)
Old 04-04-2012, 09:09 AM
Lennyg Lennyg is offline
Garage is empty, add now
Lennyg is starting off with a positive reputation.
I have a 2001 F150 XL 4.2L that had the same disintegrated compression nut of the EGR tube at the nipple on the exhaust manifold. I finally did get the nipple removed but it took a lot of work. I took the plastic wheel well off and removed the tranny dip stick tube and O2 sensor to get at the problem better. I sprayed with penetrating fluid, hammered, heated, applied pressure in both directions with a wrench, vice grip and helper bar over and over for about an hour and it finally loosened.
Then I paid the outrageous Ford parts prices (over $30 for the nipple and over $60 for the new EGR tube) and spent $30 for a tap to clean the threads. But I didn't have to pull the exhaust manifold!
  #3 (permalink)
Old 04-05-2012, 06:15 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Quote:
If he had plugged it you may have experienced engine ping at part throttle conditions.
  #4 (permalink)
Old 04-05-2012, 06:28 PM
ryoken31 ryoken31 is offline
ryoken31 is starting off with a positive reputation.
I had the EGR tube welded on my pickup in the fall. Lasted a month or two then the weld fell apart. I ended up buying a new tube from ford with the fitting for 100 bucks and a set of headers for 300 bucks. Did the trick just nicely.
  #5 (permalink)
Old 04-06-2012, 12:21 PM
Doc's Avatar
My Garage
Good information. Well it's almost been a month and so far so good on the tube (but I wouldn't be surprised if it blew off any day). Unfortunately, the famous EGR insufficient flow code has come back regularly. So my next task is to probably clean the EGR ports. I'm no expert at all on this, but it would seem logical that the ports on my truck would stand even a higher chance of being clogged considering I haven't had sufficient flow through them in some time?
__________________
Shane
1997 F150 XLT, 4.6L
2011 Expedition EL
  #6 (permalink)
Old 04-15-2012, 06:26 PM
7700Rob 7700Rob is offline
7700Rob is starting off with a positive reputation.
I recently had the manifold side nut disintegrate. I cut off the lower flange, had a short (1 1/2" long) 1/2" copper pipe that just happens to fit nice and snug in the nipple. I did up some JB Weld and mated the egr tube to the copper tube and let it sit. I did use use silver solder around the manifold nipple where the copper piece is. It's been two weeks, I haven't pampered it, and it's holding up.
__________________
Late '30 "AA" Dump truck
'30 "A" Coupe w/rumble seat
'63 Mercury Meteor Custom Hardtop
'01 150 7700 Supercab
  #7 (permalink)
Old 04-15-2012, 06:54 PM
Spotty Spotty is offline
Spotty is starting off with a positive reputation.
My nut was gone also....rust belt victim. I wire brushed it and wrapped the whole thing in aluminum tape.....like HVAC guys use in ductwork. Then put two small clamps on it top and bottom ( on the tape). Works great.,...not a peep, about 4 months now....smells kinda' funny for about a week. I had about 4 pinholes that were leaking on the manifolds. I bought a small tube of that fireplace -boiler repair stuff...like $3.00 bucks. wire brushed it first, then took some waded up pieces of steel wool covered them in that stuff and stuck them to the manifold. some are over a year old....it works slick. I've had the manifolds off before for broken studs, some day I will tear all this stuff off and do manifolds and EGR tube.
__________________
98 Ford F-150.4.6.4x4. Extended Cab 8' Box
2000 Mustang Gt, Black on Black, 100% stock
  #8 (permalink)
Old 04-15-2012, 07:57 PM
Dave G. Dave G. is offline
Dave G. is gaining momentum as a positive member of FTE.
That flare nut nipple is just a plain steel part, exactly the same thing you can pick up at any box store or hardware, for $3.00 or so. 3/8" NPT on one end and 3/8" flare nut on the other, I think. ( possibly could be 1/2"). I always have a bunch laying around, so I just use the one that fits the tube nut.
Dave
  #9 (permalink)
Old 04-15-2012, 08:27 PM
Yeah....I had some around also that would fit, but no way were those old threads coming out of that manifold. Just one huge rusty mess with no threads of any kind left...Minnesota salt. Took me 4 hours to do one tie rod end today....rust is slowly winning....
__________________
  #10 (permalink)
Old 08-03-2012, 02:08 PM
Doc's Avatar
My Garage
Just to give an update. It's been almost 4 months now and that welded EGR tube to the manifold is still holding strong. I also removed the throttle body and cleaned the EGR ports--no more "EGR insufficient flow" code.
__________________
Shane
1997 F150 XLT, 4.6L
2011 Expedition EL
Tags
1997, 460, 97, broken, connection, egr, exhaust, expedition, f150, ford, leak, leaking, manifold, repair, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
