Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
- How to Repair a Leaky Manifold
Step by step instructions for do-it-yourself repairs
Surprise "fix" to the EGR tube/manifold leak
So I've driven my 97 F-150 (4.6 L) around for several months now listening to that wretched left side exhaust leak caused by the nut on the EGR tube rotting off the nipple on the manifold. I tried plugging it, taping it with that exhaust "bandage" tape, etc. Nothing obviously ever lasted. And I sure didn't want to try replacing the manifold and then dealing with the potential broken studs, etc. Then I finally got around to getting the gas tank straps replaced with that recall. So I took it to the dealership this past Friday. I mentioned the EGR tube leak kind of in passing. The service manager said they could fix it for about 80 bucks. He said they had successfully removed quite a few of those nipples without replacing the manifold. I kind of thought to myself "yeah right" (considering I live in the rust belt with all the road salt, etc.) and told them to go for it. Not surprisingly, they called me back later in the day and said they couldn't get it out, and he quoted me an $800 price to replace the manifold, etc. I just told him to plug it instead. When I picked up the truck, I learned the mechanic decided to WELD it instead of plugging it. I was pretty surprised that he tackled it, and he actually did a pretty decent job in sealing it except for one small pin hole on the back side between the welds. I mixed up some JB Weld and filled the pinhole. The welds may fail or the JB Weld blows out tomorrow, but, in the meantime, I don't have to listen to that wretched exhaust leak constantly. At least I'll have a few days peace if not longer.
I have a 2001 F150 XL 4.2L that had the same disintegrated compression nut of the EGR tube at the nipple on the exhaust manifold. I finally did get the nipple removed but it took a lot of work. I took the plastic wheel well off and removed the tranny dip stick tube and O2 sensor to get at the problem better. I sprayed with penetrating fluid, hammered, heated, applied pressure in both directions with a wrench, vice grip and helper bar over and over for about an hour and it finally loosened.
Then I paid the outrageous Ford parts prices (over $30 for the nipple and over $60 for the new EGR tube) and spent $30 for a tap to clean the threads. But I didn't have to pull the exhaust manifold!
Good information. Well it's almost been a month and so far so good on the tube (but I wouldn't be surprised if it blew off any day). Unfortunately, the famous EGR insufficient flow code has come back regularly. So my next task is to probably clean the EGR ports. I'm no expert at all on this, but it would seem logical that the ports on my truck would stand even a higher chance of being clogged considering I haven't had sufficient flow through them in some time?
I recently had the manifold side nut disintegrate. I cut off the lower flange, had a short (1 1/2" long) 1/2" copper pipe that just happens to fit nice and snug in the nipple. I did up some JB Weld and mated the egr tube to the copper tube and let it sit. I did use use silver solder around the manifold nipple where the copper piece is. It's been two weeks, I haven't pampered it, and it's holding up.
My nut was gone also....rust belt victim. I wire brushed it and wrapped the whole thing in aluminum tape.....like HVAC guys use in ductwork. Then put two small clamps on it top and bottom ( on the tape). Works great.,...not a peep, about 4 months now....smells kinda' funny for about a week. I had about 4 pinholes that were leaking on the manifolds. I bought a small tube of that fireplace -boiler repair stuff...like $3.00 bucks. wire brushed it first, then took some waded up pieces of steel wool covered them in that stuff and stuck them to the manifold. some are over a year old....it works slick. I've had the manifolds off before for broken studs, some day I will tear all this stuff off and do manifolds and EGR tube.
That flare nut nipple is just a plain steel part, exactly the same thing you can pick up at any box store or hardware, for $3.00 or so. 3/8" NPT on one end and 3/8" flare nut on the other, I think. ( possibly could be 1/2"). I always have a bunch laying around, so I just use the one that fits the tube nut.
Dave
Dave
I have found the cheap fix!!!!! 8)
I read alot about this issue to of course fix my own! I tried the putty no go! So I got to thinking I needed a very small like muffler flare clamp so I went to Home Depot (Ground Clamps) buy four and they will have two halves and one of them will have a set screw through a hole for the ground wire to the clamp. so you need four so you can split them and have a hole on each side. remove the screw and its a hole large enough for a 1/4 inch bolt to go through so clamp around the top of the flared tube and use one between the nipple and the manifold this wont allow the clamps to slide up as u tighten so then one 1/4 inch bolt and nut and tighten evenly viola fixed and I mean completely wont leak wont melt $11.51 is what it cost for the parts and about hour and a half if u remove the inner fender plastic which i suggest! any ?s send me an email!!!
Do you have a pic of the repair you made? I get the concept but cant quite picture it.
Sounds like you have found a creative way to address this. My leaking tube is just near end under manifold, where it ends at compression nut, pin holes on tube itself as near as I can tell.
I would love a pic or a pic of a hand drawn detail showing what you did. I would really appreciate it if you wouldnt mind. I am visual learner, its hard to picture words in my mind but if I see what you are writing about...I'll totally get it.
Thanks for your help in advance.
Kay
The EGR nut and line fitting both crapped out on me over a year ago. I just used the next step down sized wrench on the fitting (used hammer to tap it down in place) to loosen it, then vise grips to thread her out. I think the fitting takes a 1" wrench and I used either 7/8" or 3/4" to loosen. I did soak it for a couple hours with PB Blaster. It might of also helped that I replaced the stock exhaust manifolds with Gibson Shorty Headers (stainless steel). The truck only had around 300 miles on it at the time. Exhaust manifolds came off real easy (as expected). It's really not a bad job to do (if the studs don't snap).
Another exhaust manifold / EGR fitting leak fix...as I see it...test of time will tell
I too have a f150 rust bucket (2002-4.6) in the salt in Massachusetts. Time will tell but homework and logic seems to look promising. The EGR nut that did connect the EGR pipe to the exhaust manifold is missing with a few lbs of other metal matter from its under belly. Well the good news is there is ample stem available along with a stainless EGR pipe. To save myself $600-$800 and scrapping an otherwise fine exhaust manifold I found what looks like a promising fix for under $30 Bucks. Using a ceramic water based crack sealent, tiger muffler repair tape, and 5 stainless hose clamps. Research says the manifold can get hot (like 1200+ degrees). That's the primary factor here. I saw other fixes from welding to aluminum tape but was concerned with the 2 metal types on the weld, and the low melting point of aluminum/alloy. Tiger muffler repair is rated to 1900 degrees, the ceramic crack fix is rated to 2500 degrees. I applied the ceramic epoxy type goo to the seam where the EGR pipe sat on the manifold fitting. I cleaned the area first with a drumel/wire brush. I then smeared it with my finger trying to get about 1/8 thick, 1" above and below the meeting. (The two sat pretty flush together without any assistance). I let the ceramic goo set for 24 hours. It didn't get rock hard as I believe it requires high heat to accomplish this..? Anyways I then wrapped the seam with the black tiger wrap. It wrapped about 3 times around fairly tightly. It is sticky enough to do that With some degree of success. I then used 5 stainless hose clamps alternating the tightner (left side, right side). I tried to position the center clamp over the seam As I honestly didn't trust the ceramic goo much in holding a union as it is really designed for a hairline manifold crack. I put 2 clamps above it and 2 below the center clamp. The clamps covered the tape almost completely. I ran the truck for 20 minutes to activate the tiger tape and we shall see. In theory it should be good. My only concern is related to the tiger tape that may becom brittle over time....? I don't have tons of confidence in the ceramic as a holder epoxy but the clamps with tape should provide most of that function.
