OH!!! Spark plug broke off in the motor!!! - Ford Truck Enthusiasts Forums
Old 03-12-2012, 02:10 PM
05victorylly's Avatar
05victorylly 05victorylly is offline
05victorylly is starting off with a positive reputation.
Well I was changing my spark plugs, wires, cap, rotor and was going to set the timing, but the third plug I pulled out on the passenger side decided it wanted to stay put in the head!
It didn't even give much resistance. The other plugs were way harder to get out, this one was just like pop...right off. Anyone have any suggestions? I was all pumped to have a nice 65 degree day to work on the truck but now I am not feeling to good!!
Any advice would be much appreciated!
Old 03-12-2012, 02:18 PM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
Title edited.
Post language and material suitable for the home or office. Do not post foul language, racial epithets or sexually explicit content in any form.
Old 03-12-2012, 02:20 PM
Sorry about that! Understood.
Old 03-12-2012, 02:28 PM
88n94 88n94 is offline
88n94 is gaining momentum as a positive member of FTE.
Wow them things were rusty. The correct size easy out and a little luck and it should come out. Hopefully the electrode down there just bends down and doesn't break off. I would soak it with liquid wrench or PB blaster first. Use a quality easy out, not a cheap one.
Old 03-12-2012, 02:43 PM
yeah its a little rusty in there! Are you anticipating easy outs like these:
NAPA AUTO PARTS
or these:
NAPA AUTO PARTS
Old 03-12-2012, 03:00 PM
The bottom one is the style I had in mind. But the top one has a better drive(wrench or socket) end on it. Whatever you feel like trying I guess. Just try to get the proper size.
Old 03-12-2012, 06:35 PM
Roger T. Pipe's Avatar
Roger T. Pipe Roger T. Pipe is offline
Roger T. Pipe is starting off with a positive reputation.
Go out & buy this stuff called Kano-Kroil. I had this EXACT scenario on my 5.8 motor...3 of the plugs did this! I really thought all was hopeless. I went to a machine shop to see what the damage would cost me to have them remove the plugs...the head guy there recommended Kroil and swore to me that if I used it, I would not be back to his shop. He was 100% right. It ended up costing him a job that he probably did not want to do! lol..but it worked! Let it sit & penetrate over night. Maybe even all day, but it WILL come out. Don't waste your time with PB blaster or the like...it won't work. While it is good stuff, its not suited for something this bad...go with Kroil...ya gotta trust me on this!
Roger
Old 03-12-2012, 06:45 PM
Quote:
Roger
where do I buy kano-kroil?
Also I have been trying to get this plug out, but i can't get any sockets or wrenches to hold on the end of the spiral extractor...just keep rounding off the extractor end. I guess its made to be used with a drill chuck or a tap wrench.
Any other suggestions on a type of extractor i can use? I bought a 4 sided tapered one , but its too larger and I also bought a spiral extractor...the spiral extractor bits well but as I said above i can't get anything to hold it w/o rounding off the end used to turn it.
So i guess in the morning I will try and get some kano kroil and a correctly sized 4 edge tapered extractor, I like the idea of not having it expand the threads and make it harder to turn.
Any advice here? this sucks bad! I got the other 7 plugs out and replaced it just this one pain in the butt.
Old 03-12-2012, 06:55 PM
Old 03-12-2012, 06:57 PM
Yeah I saw that, was wondering if anyone has found it locally...i can't seem to find anyone local.
Old 03-12-2012, 07:00 PM
If you have a Graingers locally I *think* they still sell it...that's where I got mine, but that was a while back.....
Roger
Old 03-12-2012, 07:32 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
what brand plug broke?
Old 03-12-2012, 07:54 PM
Motorcraft
Old 03-12-2012, 08:52 PM
Skip1970's Avatar
guess i will stick with bosch supers.
Old 03-12-2012, 08:55 PM
I put motorcraft coppers back in it, but I will change them yearly so I am sure it wont be an issue. Well the other 7 i put in are motor craft I still need to get that one stinken one out!!
"rare"?? dirvers side adjustable mirror. danger-ranger93 1973 - 1979 F-100 & Larger F-Series Trucks 15 11-11-2015 01:21 AM
Double Din Install F-250 Super Duty 1999 - 2003 7.3L Power Stroke Diesel 54 07-05-2015 02:21 PM
Rust repair project!!! Lots of Picture. My first attempt at body work. 05victorylly 1987 - 1996 F150 & Larger F-Series Trucks 73 04-14-2012 09:54 AM
bent frame channel where hitch attaches...advice..? 05victorylly 1987 - 1996 F150 & Larger F-Series Trucks 10 03-08-2012 08:52 PM
Multifunction switch write up strokin'_tatsch 1987 - 1996 F150 & Larger F-Series Trucks 7 02-12-2011 11:48 AM
Tags
2002, 2007, 46, broke, engine, expidition, f150, ford, motor, plug, plugs, spark, sparkplug, sparl, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
