Tow Hitch - Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer
Tow Hitch
Old 03-12-2012, 09:07 AM
77_150's Avatar
77_150 77_150 is offline
77_150 is starting off with a positive reputation.
Tow Hitch
I should have had the tow hitch/assembly added when I bought it, but did not so now I find myself in the situation where I need it. Just wondering if anyone knows if this is something that is easy to do (meaning - me do the work) or should I let Ford do it for $150? The docs that I have read said it bolts right in without any modification at all. I do not need to wiring harness right now since this will mainly be used to haul bikes.
Any ideas?
Old 04-04-2012, 11:52 AM
kmonty2's Avatar
kmonty2 kmonty2 is offline
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
Well you only needs the lights if your are towing a trailer. Sounds like a good price for the hitch installed and I would let them put the lights in at the same time. If you don't you will want to hook up a trailer the next day. I need to get put on mine too, but I got mine off the lot so no option at the time of delivery foes me to get one.
Old 04-05-2012, 09:55 AM
77_150's Avatar
Quote:
Well, that price is just the installation cost and not the hitch. The hitch can run between $300 and $465 for the Ford version. I ended up buying a Curt class 3 hitch for $140 and paid a local shop $45 to have it installed. Looks really good and should be able to handle hauling 2 30lb bikes
Thanks for your response
Old 12-04-2012, 07:46 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
Yep! Curt is the way to go. $146 on Ebay delivered. Easy install. No drilling or cutting. Do it yourself and earn the right to brag about the great look. Good luck, Jag
Old 12-13-2012, 06:06 AM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
I ordered and installed the ehitches one for a customer which I think is the Hidden Hitch. Easy install and the wiring was plug and play. Hitch, wiring and ball mount was 300 with free shipping. They have a video online which shows the install. I wanted factory on mine but wouldn't have hesitated to use them again if I had needed to.
Old 07-15-2013, 10:18 PM
Awake79 Awake79 is offline
Awake79 is starting off with a positive reputation.
What years are your Explorers? I have a 2011 XLT, and have the same problem; mine doesn't have the factory tow package, but now I want/need one installed. I didn't know if the receiver and wiring harness was a factory only thing, or if my local dealer's service department could do it? I went by the dealership tonight and saw all the new ones have a hidden hitch inside the bumper, and figured I would have to get the new bumper as well. Any info is great! Thank you all!
Old 07-16-2013, 08:15 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
Aftermarket is cheaper and better as others have posted
We actually got the hitch.and.will probably never use it ;_)
Old 07-16-2013, 08:16 AM
jdadamsjr's Avatar
Old 07-16-2013, 09:00 AM
I guess Im just not mechanically inclinded enough. After looking at the rear end I didn't see how I'd be able to mount one, and run the wiring. Appreciate the reply, thanks.
Old 07-24-2013, 10:25 PM
Old 07-25-2013, 08:26 AM
That is great! Thanks for the info!!! Of course, that still leaves me with the wiring harness, but, baby steps. hahaha! Thanks again, I appreciate it.
Old 07-25-2013, 08:52 AM
LI250's Avatar
LI250 LI250 is offline
LI250 is gaining momentum as a positive member of FTE.LI250 is gaining momentum as a positive member of FTE.
I used this. Its labeled as ProSeries but is the same as the Reese. Easy install and it came with the harness.
http://www.ebay.com/itm/2011-2013-FORD-EXPLORER-TRAILER-HITCH-TOW-W-PLUG-PLAY-WIRING-HARNESS-KIT-NEW-/221124697941?pt=Motors_Car_Truck_Parts_Accessories&hash=item337c0f1f55
Old 07-30-2013, 05:14 PM
jschira's Avatar
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by jdadamsjr View Post
Aftermarket is cheaper and better as others have posted;_)
Aftermarket hitch does not include the engine oil cooler. Factory tow package does.
Old 07-31-2013, 06:57 AM
LI250's Avatar
Agreed but the question is what to do when you didnt get the factory option. I dont believe the price of the hitch from Ford includes the oil cooler. Its the hitch only.
Old 11-17-2013, 07:14 PM
Down South 1 Down South 1 is offline
Down South 1 is starting off with a positive reputation.
I know the thread is old, I haven't been here much lately since I got rid of my last F-250 Diesel Power Stroke.
I recently bought a 2012 Ford Explorer XLT without a trailer hitch. After recovering what Ford said they wanted to install one for I decided to do what I usually do and buy and aftermarket hitch and install it myself. I bought a Reese from Flebay with the wiring kit.
http://www.ebay.com/itm/REESE-Trailer-Hitch-Wiring-for-2011-2014-Ford-Explorer-Class-3-2-Receiver-/171142835015?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2012%7CModel%3AExplorer&hash=item27d8e86b47&vxp=mtr
My question is, to get full tow ability from this hitch and since I do not have the factory tow package, will I need an add on transmission cooler?
Most of my towing should be about 2000 lbs. I have a 12' tandem axle single wheel trailer. I know, that's short trailer for a tandem axle but I figure the trailer weight is less than 1500 lbs, will have to weigh to be sure. The Golf Cart that I will be hauling is a Club Car electric and from what I read weighs 506 lbs.
Wow, I had at least a couple thousand posts here but it must be time to start over since this shows as my first post.
Husky centerline weight distribution hitch on F-350 Siriustoo Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 7 01-23-2017 02:27 PM
TC towing EvanBly Transit Connect 37 11-25-2015 05:14 PM
Ball mount stuck to receiver AppocAlexx Excursion - King of SUVs 31 08-22-2015 11:54 PM
Need advice on a good towing setup 2007 F250 V10 stv1991 1999 to 2016 Super Duty 4 02-22-2015 02:38 PM
New to towing and need WD hitch cwendel Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 11 01-24-2012 08:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
