So what did you do to your 6.0L today?
I drove it home for the first time.....I've been lurking in the shadows of the forums for a bit and bouncing back and forth between the 7.3 and 6.0. Pulled the trigger on this 6.0 this afternoon. I look forward reading through these forms for years to come.
2006 XLT with 80,000 miles.
For what I did. I spent the evening swapping out the wiring for the HID lighting with a
new harness and new lamps. The reason for the harness was it has individual grounds
for each ballast and the correct plug for the bi-level lamps. The last harness was a cut
and paste job. The only thing that stopped me tonight was that I am missing the male
half of the insulated spades and my back was yelling at me.
Sean <BR>
6.0L Tech Folder
Shawn,
You mentioned that this oil change was a 10k interval, how long was the previous?
The quantity of debris in the analysis will be altered depending on the age. The labs will give you the measurements, and some will alter the narrative of the report depending on miles, but you need to do that calculation to have a better understanding of what is happening in the motor.
Silicone can be high if with any repair work included silicone RTV, but with both the silicone and wear debris going up, the mileage factor needs to be done, especially if no RTV was used anywhere.
Dang...i used a hammer and socket to change my u joints in like 10 minutes
His is different then ours
now that Iv done Ball joints a couple times I can get that axel out with seal in good shape Might get blasted but I reused them I even had 2 new ones and decided to return them If it looks like I need 4x4 I manually lock the hubs anyways if I get stuck and shift on the fly my truck locks in and I get unstuck but it leaks and unlocks after a few needs a new Transfer valve
Shawn,
when i did the front ones the socket and hammer wouldnt have worked... the bearing caps were frozen into the couplings.. even after heating them with the torch.. i never get the fun of having easy to remove ujoints.. even when doing my s10..
Cured silicone gaskets would not kick up the silicon numbers in the oil, only RTV, although never say never as there could be some molecules free on the surfaces. I would double check all post air filter connections JIC, but some values may be elevated due the work, so more telling will be the next change and analysis. Divide your last metals numbers by 6/10 to get a relative value between the two different intervals.
i never understand what the tests are saying... thats why i posted the results hoping others could explain what it was meaning.. previous test results someone that understood them better told me the magnesium levels were to high for rotella but wanted to know what was used for the oil change prior. which i knew the change prior had been running Mobil Delvac as thats what the dealer (GM) used during their changes for diesels. Which he said they did have a higher magnesium levels as its used as a cleaning additive.
with the way im reading it - it seems like at 10K miles its pushing the life of the oil.. but like i said i dont quite understand the test results enough to make determinations.. which i looked back previous test was with 7K on the standard 14 qt capacity.. from the looks of the mileage the previous sample was taken 2500 miles before my head gaskets let go and pissed the coolant down the back side of the engine...
Heck it even looks like it has the key pad on the door....
To add to what others have said......I would change the oil and send in another sample at 3K. Don't let her idle much at all if you can. Need to see what could be causing the oil dilution from fuel. There's enough fuel in it to drop it down to a 30 weight oil. Check the air intake system out to make sure the intake post filter looks clean & dust free. Personally I would limit the oil change intervals to 4-5K until the oil analysis results settle down some.
He's showing 2.29 ppm iron per 1K miles on the first UOA (7,000 miles on Rotella). The 2nd UOA is showing 3.7 ppm iron per 1,000 miles on a 10,000 mile interval of Rotella.
Not horrible numbers, just elevated. Probably from the open engine situation he mentioned.
Was the first oil analysis on the report from when the top end work was done as well?
this was the first oil change since the engine went back together and i get a reading of 77ppm...
the first sample was taken 2500 miles prior to the engine being open... at that time it was giving the silicon reading of only 5ppm... 2500 miles later the head gasket blew and i had the engine open for about the next 2-3 months while i was working on it... with the exception of the pumps, bearings, and roller lifters i had the oil cleaned out of the engine..
Do you have the EGR cooler still installed or the EGR Delete?
