So what did you do to your 6.0L today?
  #11371
Old 11-28-2015, 11:48 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
I get 400 on a 25 gallon tank.
Changed out the block heater. Wouldn't work, wasn't the cord so I put a new one in. Plugged it the old element and it worked in my hand... tried everything to avoid pulling it.
  #11372
Old 11-28-2015, 11:59 AM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
How is your hand?
  #11373
Old 11-28-2015, 01:56 PM
acf6's Avatar
acf6
acf6 is offline
so trucks back on the road with new steering box. my truck can spin the wheels at an idle now...i had 0 power steering before at idle. the steering isnt really much tighter, but its looser now if that makes sense. like driving around town and stuff its okay, and its kinda nice cause its so light but on the highway its way too loose for my likings. should i just try tightening the adjustment bolt on top?
  #11374
Old 11-28-2015, 02:14 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Just a tiny bit at a time, but now is the time to do it before the gears get worn to straight driving.
  #11375
Old 11-28-2015, 06:17 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
Originally Posted by Shaneb75
How is your hand?
You would be surprised how fast it gets hot... before I could yell unplug it, it vaporized the coolant that was on the element and would have burned my hand. Had a shop rag on it to help hold it, it smoked as I wasn't sure what would happen when plugged in.
  #11376
Old 11-28-2015, 09:13 PM
Sparky83's Avatar
Sparky83
Sparky83 is online now
Originally Posted by KDAVID1
Hate that. I can usually get 300 to 350 on half a tank depending on my driving then from half to a bit below 1/4 200 to 250 or so.
i dunno why. I can go forever on the tank so long as the needles on full. As soon as it starts moving it falls fast
  #11377
Old 11-29-2015, 03:57 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
That is so true it not even funny.
Sean
6.0L Tech Folder
  #11378
Old 11-29-2015, 07:46 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Sean
6.0L Tech Folder
What I have seen in many tanks is the float doesn't move all the way to the top of the tank. So you have to use up all the fuel at the top of the tank and whatever is above the float before it starts to move and show on the gauge. There can be quite allot of fuel above the float depending how it is all set up and assembled.
  #11379
Old 11-29-2015, 08:41 AM
cr1msonshade's Avatar
cr1msonshade
cr1msonshade is offline
Needing some thoughts. I replaced my steering gearbox because I had almost 90* of play in steering wheel before it would start turning the wheels and was told by people (not on this site) that replacing was the only option. I got a reman unit from online and it did take all of the slack out of the wheel but after putting in the new box I am in the boat where acf6 was and I have no power steering at idle. My question is if that adjustment screw is to tight can it cause the loss of power steering at idle?
  #11380
Old 11-29-2015, 09:48 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
added these to the truck
drivers side had a big crack in it allowing moisture in... looks much better.
New block heater tested overnight, works good.
went 107 miles the other day on a full tank before the gauge started to move, sometime I wonder if i filled it to full and broke it.
  #11381
Old 11-29-2015, 10:33 AM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Sean
6.0L Tech Folder
Sparky and yahiko---yep
Funny thing even below 1/4 tank the most I've put in the tank was 38 gallons. It's a 44 gallon tank!!
  #11382
Old 11-29-2015, 10:41 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Full tank I'll get 90+ miles before the needle is even with the full tick mark.
Josh
  #11383
Old 11-29-2015, 11:19 AM
Snowseeker's Avatar
Snowseeker
Our chevy will go most of the day before the gauge starts to move. But even though it shows "full" yet you will be able to get 10 gallons in the tank.
The last 1/4 tank really flys by in that truck!
  #11384
Old 11-29-2015, 03:56 PM
acf6's Avatar
acf6
acf6 is offline
has anyone replaced the upper bushings on the front leaf spring shackles? are there even any bushings there? something is clunking bad on my truck and im pretty sure its gotta either be that or ball joints again
and i need to figure out this steering situation soon...i wish i had just left the original steering box in lol, this new one from ford just makes my truck feel like i have 0 steering input. there is 0 slop in the steering...when i move the wheel, the wheels turn instantly, but the steering is so light. i dont like it one bit. i adjusted the screw in 1/2 turn today but not sure i want to go anymore on a brand new box
  #11385
Old 11-29-2015, 04:03 PM
cr1msonshade
want to trade steering boxes im thinking about backing mine out after hearing about your old box im thinking that maybe mine is to tight from the reman company
Quick Reply: So what did you do to your 6.0L today?
