So what did you do to your 6.0L today?
are any of yall running the Cooper Discoverer A/T3 - ST MAX or BFG A/T K02's on your rides?? Michelin discontinued the tires i got on the front in the size i need.. so now looking around at others...
and Just FYI... I hate good years.. too many issues with them to ever use them again..
I did the blue spring update, installed the upgraded negative/positive battery cables as talked about in the batteries thread, tried to change the tranny fluid and tried to put on a new gator belt.
Tried to do the tranny fluid because I drained it, and discovered that the moron that changed it last put some random bolt in there. Not even magnetic!
Tried to put a gator belt on to fix some squealing under load. Got the old off, and while putting on the new discovered the idler pulley is bad. That was probably the culprit, but a new belt isn't gonna hurt!
Picking up the new pulley and drain plug in the morning and gonna button her up! Crossing my fingers I don't find something else needin replacin...
Sean
6.0L Tech Folder
on
I've run both of these tires and give a huge thumbs up to the Coopers. They are incredible tires. Great handling, even wear, quiet, good traction. In my experience, though the KO2's handle and wear okay while being quiet, I have never been impressed with the traction when it gets sloppy out.
