So what did you do to your 6.0L today?
#9886
Act, sure you don't just need to bleed and cycle the the antilock. I bet a bit of air will bleed out. Some really hard stops on wet roads will do this, then bleed again. It worked for me. If you don't have a good bleed buddy, then the Russell speed bleeders and hose into a can are pretty darn sweet.
#9887
My buddy and his dad came over and hung out and helped. He said should really do a bench bleed on the master but said if we pumped the pedal and cracked each line on it, that should work too. Went around and bled each corner and had no air when we were done.
And thats the thing...i cant do a hard stop if i wanted too. I can put my foot to the floor and my truck just gradually slows down. ABS will only kick on in the snow, never in the rain. Truck just doesnt slow down that fast
#9889
#9890
#9893
#9894
Time to look at the flex lines to see of you have one or more that
are ballooning on you.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
#9895
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
#9896
#9897
#9898
Changed the coolant filter for the first time today (5000 miles).
Wow, not a good sight. Definitely a little disconcerting.
Poured out of the filter:
Inside the filter:
All the gook from just ONE fin in the filter. I can't imagine emptying ever fin into a pile. Wow.
New filter installed and hopefully grabbing anything else in there.
Cheers,
Nate
Inside the filter:
Cheers,
Nate
#9899
Welp... $185 later for a new starter the truck started right up.. even cranked over faster than when i first bought the truck...
unplugged the EGR Valve and took it out for a run down the street... There was this strange feeling... i pushed the pedal down to the floor... and there was this overwhelming feeling to move to the back seat...
old starter...
im wondering if this is actually supposed to look like that...
nice shiny now one...
put it in.. looks nice and shiny there with a nice clean engine.. kinda sad the tranny looks nasty from the engine...
just cause i love how the gauges look together..
old starter...
#9900
Well I got around to changing my air filter today.
192g of dust in the puppy. Well it was 192g heavier than the one i put in.
Here is the manometer reading I got on the old one then on the new one.
You can ignore the bottom number.
Old Filter
New Filter
The reading is in mbar. This was done on a warm engine at idle A/C on both times.
BTW The new filter was not an easy first seal so I took it back apart to recheck.
It sealed right. It just was new and tight fit. Good seal. No gaps.
Sean
6.0L Tech Folder
Old Filter
New Filter
Sean
6.0L Tech Folder
