So what did you do to your 6.0L today?
#9860
#9861
Well I forgot to say that I got down at the auto body shop.
Bent bumper, damaged hitch and looks like the hitch hit the
spare tire. So maybe a tire also. Also with the bumper comes
the pads 2 of the 3 are also scratched. Oh what fun.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
#9862
#9864
New pads or old pads?
Even with new pads and rotors the pistons need to extend out
of the caliper. You may get a few to the floor peddles until you
have the pistons set to the right location. When I did my rears
with new pads, rotors and I had compressed the pistons back into
the calipers it took a few pumps to get the peddle back to normal.
It seemed to help some to have the engine running to give me power
to push the fluid out.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
#9866
Bleeding with it off is right.
It's the refilling of the piston bore that takes
more fluid and it can be a bit easier with the
engine running. Don't forget that you are moving
a lot of fluid to do that and if one set is already full
then your also working against that pressure to move
the peddle.
Sean
6.0L Tech Folder
the peddle.
Sean
6.0L Tech Folder
#9868
#9869
#9870
Or he needs to get some Russell speed bleeders so he can do it quick and easy by himself. Best $20 I ever spent on a vehicle.
