So what did you do to your 6.0L today?
Old 07-01-2015, 10:52 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
And it's in along with from fresh Rotella ELC
  #9317
Old 07-02-2015, 06:57 AM
Sparky83's Avatar
Sparky83
Sparky83 is offline
i see shiney....
  #9318
Old 07-02-2015, 07:20 AM
evan1242's Avatar
evan1242
evan1242 is offline
That looks nice. I'm jelly
  #9319
Old 07-02-2015, 09:26 AM
Ford_Fan1's Avatar
Ford_Fan1
Ford_Fan1 is offline
Is that the new style for EGR valve placement? I like it!!
  #9320
Old 07-02-2015, 01:11 PM
Excurvelle's Avatar
Excurvelle
Excurvelle is online now
Originally Posted by 05F250DSL
Compare those with your trans fluid temp. And iat2 after a cold soak they should all be pretty darn close to one another.
Great idea. The cold soak is overnight. I am thinking ECT because the SGII says ECT is hovering at 190 in 90 degree heat. I will check it later, I have not driven it today.
  #9321
Old 07-02-2015, 01:18 PM
Toreador_Diesel
Retired Mod
It works well, it's like Ford knew
I was too for the longest, but this.thing.is AWESOME! Well worth the money!
Originally Posted by Sparky83
i see shiney....
Had to wipe some drool off the floor, wife came home, saw me staring at it, and shook her head and walked away.
  #9322
Old 07-02-2015, 03:57 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
lol.. better to be cleaning drool than other things lol
  #9323
Old 07-02-2015, 04:09 PM
acf6's Avatar
acf6
acf6 is offline
i ordered fuel filters and this king ranch leather 2 piece steering wheel cover thing i found on ebay. i have to sew it on...should be interesting
i also need to go acquire some oil because i am about at 5k, and i dont want to run 15-40 w/o additive much past 5k
  #9324
Old 07-02-2015, 06:08 PM
acf6's Avatar
acf6
acf6 is offline
does anyone know where i can get wiring diagrams?? like for those 5 main connectors above the drivers side fender well??
  #9325
Old 07-02-2015, 06:10 PM
evan1242's Avatar
evan1242
evan1242 is offline
LOL
HERE
  #9326
Old 07-02-2015, 08:31 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Put two new batteries in while in the NAPA parking lot then filled up with 23 gallons of deisel. If it don't rain tomorrow I'll be changing out the positive battery cable and putting in a new alternator.
  #9327
Old 07-02-2015, 08:37 PM
acf6's Avatar
acf6
acf6 is offline
so over the weekend, i drove 400 miles through the rain and my throttle pedal did not die once. Yesterday, i get 2 miles into my commute to work in the rain and my throttle pedal died and it took like 30 restarts to get it going again..for it to die a mile later.
I got the idea today in the driveway, to spray the drivers fender well with water and see what happened. I was able to get it to die twice, spraying in the exact same area
that then prompted me to remove the fender liner and inspect, which i actually did find a wire that was corroded and entirely broken...but that did not seem to have an impact on anything as it still operated fine. either way, i fixed that and i took apart every connector i saw and cleaned/filled with dielectric grease. i then sprayed it with water with the fender liner out, and couldnt get it to die (this was before i fixed that wire)
i did some testing based off these charts i found on Alldata...and im not really sure if my testing is right or not...
although AG13 refers to the P2139 and P2140 codes i have, i went through the other tests as well... AG10 i tested each APP circuit between ground..and 1 and 2 both had 0 volts, and APP 3 had 7.3 volts. which then it says to find the short to voltage and fix..
AG12 i got like .3 and .7 ohms...which says to replace PCM
im not really sure where to go from here, or if even any of my testing was accurate. i just find it so strange i was able to drive 400 miles in rain the entire time without issue, then i drive 2 miles and have an issue. and then i can spray it with water and it dies...
  #9328
Old 07-02-2015, 09:31 PM
evan1242's Avatar
evan1242
evan1242 is offline
Looks like you may have your ghost.
From there I would continue driving as normal and see if it still happens.
Since reading all your troubles with the pedal I no longer move mine at all just incase.
Hopefully its fixed though. I know you must be pretty frustrated with it.
  #9329
Old 07-02-2015, 09:34 PM
acf6's Avatar
acf6
acf6 is offline
And I don't even have adjustable pedals
Nothing changed when I fixed that wire so I'm guessing it's still broken. I guess we will see tomorrow
  #9330
Old 07-02-2015, 09:37 PM
evan1242's Avatar
evan1242
evan1242 is offline
Oh didn't know that.
Maybe the grease did the trick.
It works wonders on my ATVs.
Can you still make it die with the hose after the grease?
Quick Reply: So what did you do to your 6.0L today?
