So what did you do to your 6.0L today?
#8626
#8627
#8628
Came back from my trip. Saturday April 25th to Today, 5 solid days of ATV riding, plus 2 days of Las Vegas fun.
2100 miles total.
1st leg to Green River 21 mpg
2nd Leg Green River to Mesquite 17 mpg
All the MISC trips 18 mpg
1st leg Mesquite to Green River 16.5 mpg
2nd leg Green River to Home 22.8 mpg
Mishimoto t-stat I have mixed feelings about. For the most part it held 201 ECT, occasionally would hit 203 and sometimes drop to 199.
However......
Right outside of Green River Westbound is a 30mph 20 mile construction zone, all upgrade (6%?) The ECT spiked to 207, fan was commanded to 74% and brought the ECT back down to 201-203.
All thoughout Nevada, Utah and Arizona ATV's in tow and ambient 95+ the ECT remained 201-203. No issues there.
Return trip climbing Vail I-70 Eastbound, 65+ mph the ECT again spiked to 208, and fan was commanded on. Same thing happened again just before the Tunnels, 208 ECT and the fan kicked on. This was only with an ATV in the bed, ambient was in the high 60s low 70s.
I could definitely see an issue with the Mishi 200 stat and pulling a good sized load up those grades. IIRC with the old Motorcrafts the ECT would top out about 200-204 up those same grades, same speeds and same ATV in the bed.
Interesting.
Josh
2100 miles total.
However......
Interesting.
Josh
#8630
#8631
#8633
#8635
Grease all your pins and pad holders at the same time. Friday I found a frozen pin in mine and had a heck of a time removing it. Also your year has the unibearings that can be lubed through the abs hole. May be a good time to do so. RiffRaff makes a zerk for this. First time I just shoved the grease gun in there and pumped it up and spun the bearing.
#8636
#8637
I just greased my bearings on the front a few months ago. Had to replace an ABS cable after too. Do the back ones have that too?
I know my issue is with the right rear parking brake. I took the temp of all the rotors before and after a 45 minute drive and that one was 60° hotter than all the others, especially on the drum portion of it. Plus the wear in there and the smell was a dead give away, plus my cable is pinched and split.
I think they're original, so I'm going to replace that cable and the shoes. All other pads and pins are good.
#8639
Interesting your rears need to be replaced. Are they over tight or is everything just frozen? Can you please take some pictures when you jump into it.
#8640
Speaking of brakes...Mine are acting incredibly weird. Leaving class today, the brakes were so good I almost put myself through the windshield. An hour later I had my foot to the floor trying to stop coming off the highway (at a very reasonable rate of deceleration)...wtf? I have all new ford pads and rotors and 2 front calipers 2 years ago, maybe 35k on them...checked like a month ago and everything is operating smoothly. This truck has always had poor braking power but now it's just being weird...
