So what did you do to your 6.0L today?
  #8581
Old 04-30-2015, 10:16 AM
King-bRanch's Avatar
King-bRanch
King-bRanch is offline
After I pick my daughter up from school this afternoon w/it,
I'll be removing the Trans Mount to bring w/me to the Dealer (to match up) on my way into work for the evening
  #8582
Old 04-30-2015, 11:55 AM
Sparky83's Avatar
Sparky83
Sparky83 is offline
i havent touched in in almost 2 months... im really missing it...
  #8583
Old 04-30-2015, 03:33 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Driving every day. Happy Truck
Will be heading up the road here soon so if anyone wants to meet…
Sean
  #8584
Old 04-30-2015, 09:00 PM
2006White60's Avatar
2006White60
2006White60 is offline
If I was still in the Northwest.....
  #8585
Old 04-30-2015, 09:06 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
Sean
I have a sister in Riverside and a brother in Penole, wave as you drive by... Have a safe trip Sean!
  #8586
Old 04-30-2015, 11:01 PM
Ford_Fan1's Avatar
Ford_Fan1
Ford_Fan1 is offline
Can anyone give me some honest feedback about having a tune written with the turbo brake? I can't seem to find definitive results anywhere. Some people say it is a great option to have while others worry about giant EBP readings, floating exhaust valves and unsurprisingly blowing HG's.
From my perspective, I think it would be less engine wear than using the stock tow/haul braking because the engine is constantly trying to compress air to slow down versus just shifting down and revving to 3500 RPM. I also can't imagine that compressing 20 PSI of boost is worse than normal compression with the boost/fuel mixture but what do I know?
  #8587
Old 04-30-2015, 11:07 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
I've wondered how that works, are they just closing the vanes?
Josh
  #8588
Old 05-01-2015, 06:34 AM
Ford_Fan1's Avatar
Ford_Fan1
Josh
Yes, from what I understand, the turbo just closes the vanes and builds boost to slow the truck down. I just have a hard time believing that can cause problems from too much compression.
  #8589
Old 05-01-2015, 11:51 AM
Sparky83's Avatar
Sparky83
Sparky83 is offline
the Tow Haul mode uses the turbo as an exhaust brake... use it all the time when im in hill country or have a big load in the bed..
  #8590
Old 05-01-2015, 02:59 PM
Bullitt390's Avatar
Bullitt390
Tow/haul is locking the convertor and holding a lower gear.
Josh
  #8591
Old 05-01-2015, 03:22 PM
Ford_Fan1's Avatar
Ford_Fan1
Josh
I agree, stock doesn't use turbo. If you watch stock VGT, it drops to around 30 when slowing with tow haul. When the turbo is used, vgt goes up to 85% and builds upwards of 20 boost.
  #8592
Old 05-01-2015, 03:55 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
Josh
uses the converter too... but also uses the turbo as an exhaust brake.. That's why ford DOES NOT recommend putting an exhaust brake on the diesels with the VGT on them. It closes the vanes to increase the back pressure in the cylinders.
  #8593
Old 05-01-2015, 04:13 PM
Bullitt390's Avatar
Bullitt390
As per Mark K:
On the 6.0L with the five speed TorqShift automatic the Tow/Haul mode:
First, it makes he upshifts at a higher speed. This prevents lugging.
Second, it provides engine braking by automatically downshifting the transmission when you are slowing. It also can downsift at a higher speed if you are on the brakes. It's real effective at maintaining speed down a grade.
It does not prevent shifts to overdrive.
Tow/Haul has nothing to do with the turbo
  #8594
Old 05-01-2015, 04:38 PM
Ford_Fan1's Avatar
Ford_Fan1
The turbo does not act as a brake on stock tuning. On stock tuning, the turbo opens the vanes and builds almost no boost or back pressure when decelerating. If you watch VGT while slowing down in tow/haul you will see that the VGT actually drops when slowing down on stock tuning in tow/haul. Tow tunes with the turbo brake written into them use the turbo as a brake by closing the vanes which in turn spins the turbine faster to build boost in the cylinders while only allowing a small amount of exhaust to exit the downpipe.
  #8595
Old 05-01-2015, 04:49 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
all i can tell you is what ive had FORD and Powerstroke Performance guys both tell me.. The ford guys i talked to claimed to be the ones who actually designed the 6.0 and how it worked. But seemed like everyone here holds the Powerstroke Performance guys as the all time Gurus as the go to guys for the Powerstroke engines knowlege. If i go off that reputation they seem to have here id have to believe they were telling me the truth... But if yall are saying they are also wrong i dont know what to tell you then.. I was asking about adding exhaust brakes onto the 6.0's system and that was the reason/explanation they gave me.
Quick Reply: So what did you do to your 6.0L today?
