So what did you do to your 6.0L today?
#8551
No I haven't its in stock condition. My main concern was getting it running and to drive it a few days and see what else it needed. then I was planing to start bullet proofing it. I am going to have to start from the beginning it has nothing done to it, no gauges, no nothing so I'm going to have to come up with a list of what to do to it.
#8554
The other day....
Removed & inspected the Driver's Side Cab-Mounts (that I replaced 2 years ago w/Poly's) trying to find that damn annoying "clunk"
I get when turning while going over bump's ---- They are just fine BTW
Removed Front Sway-Bar to verify that wasn't making the "clunk"
I also removed the Front Drive-Shaft, to grease slip-yoke & verify that didn't have anything to do with "clunk"
* Drove w/both removed & u guessed it still there
While I was doing that my lovely Wife cleaned the Carpet w/her new machine
#8556
Today....
Re-Installed the Sway-Bar (w/new Bushings) & F.Drive-Shaft
Also drained 2 qt OIL to add a bottle of that "Hot Shots Secret"
I have almost put 2,000 miles on my Truck in nearly 7 months, so I figure that additive will be in there for some time before I hit 5,000 miles
(nothing wrong w/her, just wanted to try it)
#8557
I've recently replaced :
1. All 4 Ball-Joints (had 1 bad upper)
2. both Knuckle Seals
3. both Dust Seals
4. both Hub Bearing Assemblies
5. Sway-Bar Bushings
& it still sounds the same
I had figured it was due to the bad Upper Ball-Joint it had for awhile & after I fixed all that crap Iam now chasing the "clunk" (which isn't actually bad, I just hate it) but I guess being a 2006 w/almost 127,000 miles, I guess its getting time to re-fresh things....
* Iam hoping it may be due to the Transmission Mount, the Rubber isn't attached to the Steel bottom anymore & clunks around. I removed the 2 nut's & jacked the Trans outta the Cross-Member, after I noticed it appeared to be sitting crooked.....Fingers Crossed
Last edited by King-bRanch; 04-27-2015 at 10:33 PM. Reason: Added Info about the Trans Mount
#8560
Does anyone have any preference for a DD economy tune between QT Vivian IDP Eric? I just want something to be a slight upgrade (30-50 HP) over stock but not have crazy EGT's or cylinder pressures. I will also be looking for some tow tunes in the near future and want to pick between GH matt, QT vivian, and IDP Eric.
#8561
Rusty, I never know what to say. But if you need to talk you have my # still if I recall.
What about shock bushings? I have the bump and squeak also. I know it's time for new ones.
Sean
Damn, if 1 of us figures it out....Share
3. both Dust Seals
3. both Dust Seals
Sean
#8562
#8564
3. both Dust Seals
3. both Dust Seals
i have 153,000 miles
#8565
Where our Rd & the main Rd meet is a huge hill crest & it normally pop's as Iam turning off/onto our Rd
When I get this figured out, I'll let u know
