So what did you do to your 6.0L today?
#6811
worked on dads truck earlier after i got home from work... his lack charging light came on - on his way to work... and the needle was reading low.. he went to come home it read good.. till he got half way.. then the light came on again and needle started jumping around... pulled the alternator when i got home.. it apparently had teeth...
#6814
#6817
Filled it up...added some white power service. Its about 20-25* degrees here but my trucks running down to 184* on the highway now. Seems kinda low, its not that cold..i just replaced my thermostat last winter too, with motorcraft. At least my oil temps aren't going much over 195 though, even when coolant gets back to 188
I was also playing with my gopro and took a cold start video...sat for 24 hours and started it in 20* weather
.....and it decided to only record audio. so, forget that
#6819
#6821
#6822
This is the list of sizes they are offering, and when they will be available.
http://social.bfgoodrichtires.com/BF...ailability.pdf
Well I guess that solves that...
I don't have the money to do my suspension right now so I'm probably just going to bet a set of stock size General Grabbers or something to get me through the winter.
Then, when money is available, get a new set of rims and tires to go with a 4 inch or 6 inch lift sometime next spring or summer.
#6823
Drove it to school...driving it to work and then school tomorrow. I realized I've had 4 different jobs this year, some at the same times. I was an electrician and snow plowed occasionally, then a lineman in training (still in that process), then construction, now im back to electrician tomorrow. Wallets still empty though, lol
#6824
