So what did you do to your 6.0L today?
#9976
havent decided yet.. he suggested swapping the injectors positions and see if the codes follows them. but what bothers me was cyl 7's injector was just replaced about a yr ago at the dealer..
am curious though if maybe its a pressure leak.. for those of you running Scan Gauge 2's.. when you watch the ICP readouts.. what do you see on full throttle?? i know minimums supposed to be 500 for start up and about 650 for idle.. but can never find one for full throttle reading..
#9978
problem being there is i "messed" with the engine.. which their warranty would be invalidated because of that.. then theyd tack on the fact that even if they did wont warranty it without the replacement of the other 2.. which i cant afford to have them do..
#9979
wish i could afford to replace them..
#9980
I don't recall just when I took these.
But you can see how #2 is pulling #1 down. #7 is a new injector and so is #8. Mite not be a bad idea for me to think about 2 & 7 at this point.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
#9982
With back surgery looming. By long trips will be limited for the next 3~4 months.
How ever I can fly is someone has tickets. < Hint >
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
#9985
#9987
#9988
#9989
After the coolant change to Rotella ECL... this morning she let a little loose from somewhere other than the degas cap. About 1/2 gallon on the ground after I pulled into work.... wonder where its coming from is killing me as I sit here inside to office and stare at it. Wonder if she knows I'm pissed off?
