So what did you do to your 6.0L today?
What are y'all paying for a gallon of vintage DELO now?
While working on my exhaust, I noticed oil dripping down from passenger side (at intersection of engine and transmission). I checked CAC boots but they are dry. I may get my Milwaukee bore scope and look around today. Any suggestions on common leak areas?
Been chasing a noise for near two months now. First turbo, checked that and radial play was uuugge. Then the power steering pump was making noise, that went
Now the left turns seem to make noise, replaced the bearing under warranty today. Moog lasted September 2014 until now, 2.5 years. Was ground up metal in the grease in the hub. Both slide pins were froze solid and the left front was eating the inside pad. Would have failed inspection for sure.
Turns smooth, brakes great... still got the noise, it's at 1400 rpm and it's killing my wallet.
Frank n beans now I know why I can't find oil in the store , hope ya got a good deal,
I put the 6.0 to work , she don't like just sitting around looking purdy like dura max's do lol, so so I gave her a pat on the top and she hauled a few loads of Railroad ties , she didn't even bat a Turbo brow just keeped on working as usual, just another great day behind the wheel
Pulled the valve cover. Man i like the m12 ratchet. Watched a few videos on the ordeal. Got to the dummy plugs. Went to autozone bought long allen bits and a 12mm torq socket. Returned and finnished dissassemble. Looked over the injectors swapped in the new ones into #1,#3 holes. Started torquing everything back. Learned the stand pipe needs to be installed first. So i pulled the oil rail. Installed the stand pipe. Got the valve cover on and lost a 12mm socket behind the motor. Finally was successful at retrieving it. Buttoned the truck up. Broke out the jumper cables and hooked up to the 6.7. Then after a few cycles to fill up the injectors with fuel i cranked amd waited. Cranked and waited. Then the truck started.... it ran smooth purred along. Dont know about this work out the air business as it was smoother then it has ever ran. Got in the truck after about 30mins of run time and took a spin. Everything was perfect. No bucking in 6th between 35-40 which it would buck at anything below 55 in 5th. I didnt get on her to much as i was cold and didnt really want to find out i didnt get the boots tight on the turbo or intercooler. Picked up dinner headed home to get pulled over for a faulty tail light. Almost got shot. Ok well not really ended up with a warning amd talked about willie being on in the radio in the truck. So overall im happy truck seems to be doing 111% better. Injectors were easier than i expected
