So what did you do to your 6.0L today?
  #15841
Old 12-03-2016, 02:09 AM
FrankNBeans's Avatar
FrankNBeans
FrankNBeans is offline
Originally Posted by Sparky83
i used a ratchet strap and a pry bar till it slipped into place... i had techs suggest loosening the turbo to get them lined up then tighening the v-band clamp... but i found the ratchet strap easier...
i just watched a YouTube video on using a ratchet strap to pull the Y pipe tight against the turbo. I will try that this weekend. But, looking at my gap, it doesn't look like I'm far off from getting the Y pipe seated against the turbo. But, I obviously have a leak so I'll try the ratchet strap.
  #15842
Old 12-03-2016, 11:01 AM
duste's Avatar
duste
duste is offline
​​​​​​​Well that went pretty smooth this am. Took about an hour to fix my leaks, found another one while I was at it. I loosened the drivers side bolts on the manifold, loosened the y pipe clamp till I could move the Y pipe by hand and used the ratchet strap, super easy. Just drop the hook in the Y of the pipe and hook it to the rad support on the right side. Tightened the clamp and knew it was better right away. Take note of the threads showing on the clamp before you start and once it goes into place there will be 1/4 inch more showing when tight. A gentle tap , and I mean gentle on the band of the exhaust will help it seat better, it is the vibration not the force that helps. Got 3 more full turns on both exhaust after tapping the clamps. I used a soup can , some tape for a seal and a fitting to put air into the tail pipe to leak check it once I was done. This was how I found me second leak at the exhaust pipe itself. Road tested and no more air leak sound or stink in the cab. Here is a couple pics to add note.
  #15843
Old 12-03-2016, 11:26 AM
530ktmpilot's Avatar
530ktmpilot
530ktmpilot is offline
Added one of those deezee soft open tailgate kits. Nice not having to need both hands to open the tailgate now.
  #15844
Old 12-03-2016, 02:49 PM
BjornF16's Avatar
BjornF16
BjornF16 is offline
Upgraded crap Chinese made 110a alternator to USA assembled L-N 230a with associated plumbing upgrades to support additional current.
Bought two of these steps for $25 each from Northern Tools (on sale in store):
Ironton Extra-Large Folding Work Platform — 225-Lb. Capacity, 40in.L x 15in.W x 19 5/8in.H | Folding Platforms| Northern Tool + Equipment
EDIT:
Also picked up a Battery Minder Plus at NT for $19.99 (also available at Amazon https://www.amazon.com/BatteryMINDer.../dp/B000P23HZS)
  #15845
Old 12-03-2016, 03:02 PM
Euroman's Avatar
Euroman
Euroman is online now
big achievement today, didn't total the beast.
had a mate behind me in his Audi so was tanking on. took the 40mph hill to the house at 70, there's a 4-vehicle accident behind a blind bend - police, recovery, everything. lock up the wheels, no oncoming traffic so off the brakes pull out and get past. police not happy - rightly so - but get to live another day
  #15846
Old 12-03-2016, 06:21 PM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
Swapped out the lift springs with no blocks for OEM springs and factory 2" blocks. It lowered the rear by 1.5" and rides a lot better. The truck sits exactly level now with the front 2.5" spacer. I plan to lower the front down so it has about 2" of rake.
  #15847
Old 12-03-2016, 07:11 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,373 Likes on 2,076 Posts
Since the alternator question went big, your posts went to ------- HERE
  #15848
Old 12-03-2016, 07:39 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Thanks John.
I am done with anything at O'Reilly. They have to order the part
and the people at the store can't do it without the manager to ok it
and he won't be in until Tuesday. Just stupid.
Sean
6.0L Tech Folder
  #15849
Old 12-04-2016, 05:38 PM
duste's Avatar
duste
duste is offline
I took the old girl on her first decent trip towing the sleds, 300 mile round trip , worked awesome, no more exhaust leak or stink in the cab and I am thrilled with the fuel mileage it delivered. Didn't know the trailer was back there at all. Becoming a bigger 6.0 fan after every drive.
  #15850
Old 12-04-2016, 05:40 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
Got the tire switched over to the new rim and bolted it into its riteful place. Lil duallys happy to not have the spare anymore. Thank you Bill for the help getting the new one.
After getting it on i did another driveway alignment. Tired of this cocked steering wheel crap everytime i do something in the suspension. But guess that just shows how worn out the other stuff was.
  #15851
Old 12-04-2016, 05:59 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Looks nice. Now you have to buff the other three out and re-clearcoat. Yes I know more WORK.
or you can just drive and find a mud puddle and go splashing in it.
Sean
6.0L Tech Folder
  #15852
Old 12-04-2016, 06:04 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
Sean
6.0L Tech Folder
i buff them out in the spring... usually holds up for awhile...
im sure shell find some mud... the gravel driveway at the other house is quickly turning into a dirt road... when it rains it becomes a muddy mess...
  #15853
Old 12-04-2016, 07:17 PM
Per4mance's Avatar
Per4mance
Per4mance is offline
Your welcome,anytime you need more stuff let me know,I'll see how much I pay for it. That was a big discount for ya. I have my eyes out for some rubber too.
  #15854
Old 12-04-2016, 07:40 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
im hoping theyll wear out before i need em lol.. alignment killed the front 2 w/in 10,000 miles of my owning it... they looked brand new when i got the truck... but 10K later they were worn out on the outside... i still have one of them because it still looked in good shape... but the rear 4 i worn out till i had to buy them last year... not sure what ill put up there when it comes time...
  #15855
Old 12-06-2016, 07:10 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
In keeping with tradition, brought home a Christmas tree with mine
Quick Reply: So what did you do to your 6.0L today?
