2wd Front Rotor Wheel Bearing Question - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-11-2012, 07:43 PM
satwood's Avatar
satwood satwood is offline
satwood is starting off with a positive reputation.
Hi, I searched this SD forum but could not find a direct answer to my question. I'm picking up new front rotors for my 03 F350 dually. If I clean and inspect the old wheel bearings and don't see any problems, can I reuse them or is it much better to buy new bearings? I know the old bearings are worn into the races in the old rotors, so do I risk problems effectively giving them new races to ride on?
Thanks in advance for your help.
Steve
Old 03-11-2012, 08:44 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
With what you stated about the old races if it were me I would just buy new Bearings and not risk having problems.
Old 03-11-2012, 10:10 PM
northwindone's Avatar
northwindone northwindone is offline
northwindone has a very good reputation on FTE.northwindone has a very good reputation on FTE.northwindone has a very good reputation on FTE.northwindone has a very good reputation on FTE.
I have been told in the past that wheel bearings and races are manufactured to be matched sets and that if you replace one you are supposed to replace the other. In fact when you put new bearings in you aren't supposed to mix up your new races and bearings and keep them matched up as as they were in the box. I don't know how accurate this is, but it makes sense to me. It actually brings up a question, can you even buy races by themselves? I always thought they were sold together and new rotor hubs came without races.
Old 03-11-2012, 10:24 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Go to Autozone and get some Timken Wheelbearings. I got some on mine and they're still turning nice and smooth. Matter of fact, I think they need some grease...
Old 03-12-2012, 04:36 AM
1973Ford2004 1973Ford2004 is offline
1973Ford2004 is gaining momentum as a positive member of FTE.
Quote:
I just did this yesterday on my wife's trailblazer, Timkken is the way to go, IMO and Auto zone works for me, but stay away from the Duralast line.
Old 03-12-2012, 09:43 AM
Onus's Avatar
Onus Onus is offline
Onus is gaining momentum as a positive member of FTE.
I don't have a superduty but the twin i beam system hasn't changed much from my truck to the super duty. I'd just get new bearings if your replacing the rotors. They are not much more price to add on. Also don't forget the seals either. My local napa store hooked me up with all the parts i needed.
Old 03-13-2012, 01:41 PM
satwood's Avatar
Thanks guys. I finished this last night. I put in a full new set of Timkens from Napa and everything is back together. I did almost forget the cotter pin on one side, my wife pointed out that little pin laying on the towel while I was hammering on the dust cap. She earned her date night with that one!
The new rotors came with races pressed in. The new bearings also came with races - and yes, you can buy just races because the outters came in seperate boxes. I did not want to press out the races in the new rotors to put in the ones that came with the bearings. I've never done that before and I guess if that was a bad thing then why would they put new races in the rotors anyway?
Incidentally, as I'm sure all of you have encountered, those brake caliper bracket bolts are really hard to get loose. Part of the issue is the rusted heads that required I hammer on the 13/16 socket, which then gets stuck and won't come back off. I used a 21MM 6 point socket instead, which still grips the head well enough but does not get lodged. That and a breaker bar and a 3 foot cheater pipe did the trick. Try that if you get stuck.
Old 03-13-2012, 02:17 PM
Quote:
Thanks for the follow up, I guess that disproves what I was always told. Good to know though since I'm thinking about replacing the front rotors on my 2WD Hardbody due to warped or uneven rotors. I just did the bearings on it last year and I really didn't want to have to deal with pressing new races in again.
Old 08-02-2012, 12:40 PM
flyboynd flyboynd is offline
flyboynd is starting off with a positive reputation.
2wd Super Duty front bearings-machine shop or me?
I got the rotors off my 2wd 2000 f250, can I put the new bearings in, or should I take it to a machine shop?
Old 08-02-2012, 01:48 PM
It's real easy to do yourself, just gently knock both of them out with a block of wood and you're good to go...
O'rielly auto even has a tool to pack the bearings before you put them in.
Old 12-30-2013, 04:52 PM
mohoneywell mohoneywell is offline
mohoneywell is starting off with a positive reputation.
These bolts are Locktite'd in, heat the threaded area with a torch to soften the glue.
First Time for Wheel Bearings jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 06-12-2016 05:13 PM
96 F150 Front Brake rotors jim milewski 1987 - 1996 F150 & Larger F-Series Trucks 8 03-18-2016 06:25 PM
Sloppy front wheel bearings 2wd oldstylefseries 1997 - 2003 F150 3 06-28-2014 01:21 PM
Hub/Rotor requires bearing and race? 2000 4X2 Ex Elmo154 Excursion - King of SUVs 7 04-05-2011 08:22 AM
2WD Front Wheel Bearings J.McConnell 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 04-21-2009 12:19 PM
Tags
2003, 2wd, bearing, bearings, change, duty, f350, ford, front, hard, heavy, installation, super, superduty, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
