Tire pressure? - Ford Truck Enthusiasts Forums
Tire pressure?
Old 03-11-2012, 05:00 PM
Gundown64's Avatar
Gundown64 Gundown64 is offline
Gundown64 is gaining momentum as a positive member of FTE.Gundown64 is gaining momentum as a positive member of FTE.
Tire pressure?
This seems like a silly question to ask, but I am a little confused on what my tire pressure should be at considering I have larger tires. The sticker on the door panel says I should be at 35 psi cold and the tire just says to refer to that, but says something about 40 psi max. My PSI for all my tires is about 42-43 psi and they haven't been adjusted since the tires were put on in June last year by a local shop, so I just assumed they got the PSI correct. So what should my PSI be at for all four tires? Thanks!
Old 03-11-2012, 05:33 PM
bigunit54's Avatar
bigunit54 bigunit54 is offline
bigunit54 is gaining momentum as a positive member of FTE.bigunit54 is gaining momentum as a positive member of FTE.
your fine at 43. I am running mine at 40psi. If you wanted a little softer ride you could go down to the 38 range or so.
Old 03-11-2012, 08:22 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
Mine are at 45 lbs, but I have 10 ply tires. Your main concern should be full contact of your your tire to the road. Try putting some paint across the tread and drive, slowly, one or two rotations. Look at the paint on the road. Thin paint on the sides, too much pressure. Thin paint in the center, too little pressure
Old 03-12-2012, 12:02 AM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
You should test your tire PSI often. The PSI will vary with the air temp and road temperatures. Also if you make long hauls. The tire will heat up if under inflated and possibly damage the plies. Stay below the load rating and PSI maximum rating on your tires.
Old 03-12-2012, 11:46 AM
Gundown64's Avatar
Thanks for the input guys.
Old 04-16-2014, 04:51 PM
Shawn conard Shawn conard is offline
Shawn conard is starting off with a positive reputation.
I have a 90 ford f250 4x4 with dana 60 axle swap and i have bf Goodrich all terrain ko 295 75 16 just a daily driver no towing nothing. What air pressure should I use for an even wear?
What do you do? Your tires should be close to max PSI when you are towing. Tnriverside Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 29 03-22-2016 03:20 PM
Another tire pressure question Matthew Barnes 1999 to 2016 Super Duty 9 11-14-2015 06:58 AM
305/70/16 air pressure RussEx Excursion - King of SUVs 23 04-30-2014 04:39 PM
Tire Pressure 1L243 Brakes, Steering, Suspension, Tires, & Wheels 2 11-14-2011 05:25 AM
tire air pressure dunbar15 1999 - 2003 7.3L Power Stroke Diesel 20 06-17-2005 11:20 AM
Tags
1967, 1977, 2008, 49l, 64l, f150, f250, ford, forums, lariat, pickup, pressure, psi, tire, tires, toyo, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
