Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
  #1 (permalink)
Old 03-10-2012, 09:05 PM
Glynn Glynn is offline
2002 Ford Explorer
Glynn is starting off with a positive reputation.
Airbag code 32
Newbie here - pretty sure this has been covered elsewhere, but I can't find it! My 2002 Explorer has a code 32. If the horn and cruise control are still working can I assume the clockspring mechanism is OK and that the problem lies elsewhere? If it is elsewhere what should I be looking at?
Thanks!
Glynn
  #2 (permalink)
Old 03-11-2012, 10:31 AM
shorod's Avatar
shorod shorod is offline
2010 Lincoln MKT
My Garage
shorod has a good reputation on FTE.shorod has a good reputation on FTE.
I don't think you should assume the clockspring is not the problem since there are multiple contacts in the clockspring assembly, so depending on which circuit is broken will change what features don't work.
Now this doesn't mean you should change the clockspring and assume all will be well without doing some further diagnostics....
-Rod
  #3 (permalink)
Old 04-13-2012, 10:36 PM
real_texan real_texan is offline
Garage is empty, add now
real_texan is starting off with a positive reputation.
I have airbag code 49 on 03 explorer. Does anyone know what that means. I also have a door ajar light that won't go off either
  #4 (permalink)
Old 04-14-2012, 08:25 AM
shorod's Avatar
2010 Lincoln MKT
My Garage
There are are a few different possible definitions for an LFC of 49. You'll need to use a scan tool with SRS software to determine which specific issue your system has identified. All the definitions relate to the Seat Track Position Sensor Circuit.
The door ajar light is a pretty common issue, you can find all sorts of typically solutions with a quick search of the forum so I won't go in to details here. Most involve either a bad/dirty door pin switch in the latch mechanism, a broken wire to the rear liftgate glass, or a broken wire in the accordion boot between the cabin and the driver's door.
-Rod
Tags
1999, 2002, 32, 49, airbag, clear, code, duty, explorer, f150, ford, ranger, srs, super, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
