Sheet metal availability - Ford Truck Enthusiasts Forums
Old 03-10-2012, 08:06 PM
62FE4x4 62FE4x4 is offline
62FE4x4 is starting off with a positive reputation.
Hey guys, I have found a 59 F250 factory 4x4 I am wanting to buy. Do any companies carry sheet metal parts for the 57-60 models? Thanks
Old 03-10-2012, 08:19 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
A few of the main-stream truck vendors sell repair patch panels, and Dennis carpenter reproduces the Styleside tailgate.I believe that's about it.No complete fenders, hoods, door skins that I'm aware of.
Old 03-11-2012, 07:21 PM
That is strange. I see these old pickups everywhere. You would think parts would be more readily available.
Old 03-11-2012, 07:23 PM
ibuzzard's Avatar
Get used to it.And,get a small storage shed and fill it,is my advice.
Old 03-11-2012, 07:38 PM
Well I just bought the 59 F250 4x4, and I bought a rust free F100 so hopefully I will have everything I need. Don't the 61-66 models have a much greater selection on parts availability, or are they very limited as well?
Old 03-11-2012, 07:41 PM
ibuzzard's Avatar
Yes.When you can buy parts at excellent prices,stock up your parts shelf.Some parts are difficult to find.You may not need them now,but you will some day.And like-as-not,when you need them most,they'll be hard to find.
Old 03-11-2012, 07:48 PM
I agree. Did Ford use the same flareside bed from 1958-1979? I have a 62 with 78 running gear that I want to swap the under bed fuel tank, bed, etc. to my other 62 with factory 62 running gear.
Old 03-11-2012, 08:07 PM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
Not new but clean rust free used parts
http://classicfordtrucks.shutterfly.com/
Old 03-11-2012, 10:16 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Quote:
Wow, a junior user that knows the difference between a Flareside and a stepside! Give that man a Cupie Doll!
Old 03-11-2012, 11:08 PM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
Flaresides rule. And those that know the difference are true ford guys.....
Old 03-11-2012, 11:17 PM
Haha I may be a junior user, but that is only because I have forgotten passwords to two previous accounts. Haha I have had 7 flaresides, but I still don't know the answer to my question. Can anyone chime in with the differences over re years so I will know if the 78 fuel tank/bed setup will work with my 62 frame? Thanks guys
Old 03-11-2012, 11:24 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
VFN Fiberglass (VFN Fiberglass - All your fiberglass parts) has glass hoods. B & E Fiberglass, Inc, has full fenders. I don't have a web site but their email address is b-efiberglass@arvig.net. Stu
Old 03-11-2012, 11:46 PM
Les Knapp Les Knapp is offline
Les Knapp is starting off with a positive reputation.
Les
I have both doors, both finders, hood, and lower part of the grill, both headlight brackets, and tail gate for 57-60 F 100.
Also I have both front finders, left door for a 61-66 F 100-250, grill/top part for the hood latch, for 61 F 100-250. I've got other Ford parts too.
Call me at 541.660.2344
Old 03-12-2012, 12:22 AM
elgemcdlf's Avatar
They are not the same. The '73-'79 truck widened the rails just behind the cab. It is also 2" longer than a '67-'72 bed. The '67-'72 trucks are 2" longer in wheelbase than '61-'66 trucks but I do not know where. It may be in the cab area so it might be the same bed as yours & the '67-72. Not a complete answer but hopefully it helps a bit.
Old 03-12-2012, 01:51 AM
That definitely helps. Now we know the 78 bed will bolt into the 62 frame without any mounting issues. What about the 78 fuel tank behind secured to the 62 frame?? I believe the 62 frame is narrower than the 78? Will the fuel tank (behind rear axle) still work?
Sheet metal for tool box GaMachinist 1973 - 1979 F-100 & Larger F-Series Trucks 3 06-22-2014 11:28 PM
Electric fan swap again Rainmaker68 Ranger & B-Series 2 05-23-2014 02:05 AM
What Gauge Sheet Metal fo Floor Boards Ripcity 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-12-2013 10:45 AM
Sheet metal seems thinner now Arctic Fox 2009 - 2014 F150 22 05-12-2011 01:34 PM
'51 COE sheet metal Pudmullet 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 10-20-2006 11:27 PM
Tags
62, econoline, f250, ford, metal, sheet, sheetmeral, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
