You working on the bearings too? wow, last I spoke with you, it was just a hub project.
Yep. Bearings are shot. I just can't seem to catch a break. The good news is that I won't have any thumping, banging or vibrations when I'm done. The bad news is that I won't be able to leave the driveway because I'll be broke LOL.
They say the hubs/bearings take a beating when you do large tires/lift. If you remember the truck had 37.5" tires on it when I got it. CRAZY!!!!
Yeah, plus you said it looked wet when you took the hubs out. Make sure to replace the seal in the back, where the bearing sits. There is another bearing inside of the spindle that the axel rides on, but if your not going down that far, don't worry too much about it
Seals will get replaced don't worry about that LOL.
They leak, but usually not real bad. even our 02, with less than 20,000 miles, has moisture on places, but it never drips. I don't fret too much about it.
If that truck pulls a trailer like ours, you'll be happy
What are you pulling with your truck? Ya I suspect I won't have any issues pulling. LOL. The loaded up weight is probably around 8k max and that's guessing high.
