I'm using an MGT Blendmount which mounts the Scangauge above the mirror. The cable is routed along the trim down in under the dash so you can't see the cable. I did need to buy an extension cable which is just a cat 5 or 6 cable.
I used a suction mount from a gps unit I have that no longer works. After a little trimming I used the provided velcro to hold the ScanGauge II unit to the mount. Works great.
