Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1967 - 1972 F-100 & Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 03-10-2012, 03:16 PM
48prerunner's Avatar
48prerunner 48prerunner is offline
Garage is empty, add now
48prerunner is starting off with a positive reputation.
newer f model hydraulic clutch in a bump
Anybody have pictures of a hydraulic clutch set up from one of the newer fords adapted to a bumpside? wonder if the pedal assembly will work from the newer truck?
I've looked at tech drawings looks like newer truck has clutch master cyl to the right side with a lever to work the push rod.
I have a crown vic front cross member installed and i'm going with a mod motor either a used 4.6 3 valve or a new 5.0 . For transmission I'll be running either a 3650 from a 2004 or older mustang for ease of shifter hookup, or if i can figure out how to move the shifter forward maybe a newer six speed. I hope to use the hydraulic throwout bearing from the 2005 and up mustang. Just looking for an easier way to hook up the clutch pedal to the clutch master cylinder than having to fab a bracket off the existing clutch pedal like they did on the bumpside build off. http://www.classictrucks.com/tech/0710c ... ewall.html
Maybe should have posted in the newer sections?
  #2 (permalink)
Old 03-10-2012, 11:07 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
1969 Ford F-250
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Click the image to open in full size.
I did mine there to prevent cylinder head-MC interaction issues. Basically, I pulled the clutch pedal out, drilled a hole and inserted a long 3/8" grade 8 bolt, which I then cut down to about 2" so it was just the smooth part, not the threads. The master cylinder pushrod eye slips over this, and I also put a shaft collar on either side of the pushrod eye so it would stay in place.
If I were to do it again, I'd probably move the master cylinder off to the left about 1/4" more, since it's a bit too close to the brake master cylinder bracket.
__________________
Jared
Real trucks have the key on the left
FTE Guidelines
Tags
models, powered, search, vbulletin, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
