How to replace your 4.6L spark plugs - Ford Truck Enthusiasts Forums
Old 03-10-2012, 01:41 PM
HULKTANK HULKTANK is offline
HULKTANK is starting off with a positive reputation.
Periodically, my 2003 150 superscrew with 4.6L starts miss firing, the check engine light obviously comes on when this happens. Took it to the Ford Dealership and Big-O-Tire and they both told me that it it #1 spark plug that misfires. Big-o-tire has taken the #1 plug out a couple of times to drain water that comes on there and take the plug out to clean. This seems to happen when it rains and water gets on there. My truck has just over plus 100,000 miles and I had already had the tuneup. All the plugs were brand new. The #1 plug that periodically gets water around becomes rusted. Any suggestions on the water issue or overall.Thx
Old 03-10-2012, 08:56 PM
kidzstang kidzstang is offline
kidzstang is starting off with a positive reputation.
Weird that number 1 plug would get rain on it. Are your sure that it isn't a slight coolant leak either from the Tstat or intake area?
Quote:
Old 03-11-2012, 01:05 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Have you ever changed the COP plug boot? They can take set from heat and not seal properly when reinstalled after a plug change. That will allow road splash into the plug well and may start a misfire condition. Install a new boot and spread just a little dielectric grease inside the boot that slides over the spark plug. Don't fill the boot with grease, you don't want dielectric grease on the spark plug's terminal to COP's coil spring contact.
water in spark plug recess cardone 1997 - 2003 F150 24 11-09-2015 09:39 AM
My experiences with Gooch's coolant flush procedure AMG-SM 1999 - 2003 7.3L Power Stroke Diesel 28 05-09-2015 01:55 PM
How Do I Change the Spark Plugs? 2006 4.6L TomBrooklyn2 1968-2013 Full Size Vans 9 02-05-2015 06:51 PM
Used Time-Sert Ford Triton Spark Plug Repair Kit # 5553 RyanP0342 Ford Truck Parts for Sale 2 06-13-2014 09:16 AM
So it CAN happen... stumprider69 1997 - 2003 F150 7 05-17-2014 02:43 AM
Tags
1997, 46, 46l, 54l, change, expedition, f150, ford, fuel, injected, liter, plug, plugs, replace, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
